missing cam
Is it just me or does your header look f-d up??
Yup, they have that little pinch in them.
I have both heads off and the pistons/block surface cleaned up and ready for the heads. I am working on tapping the block holes and will probably bolt the heads on tonight. Fucking autozone shit taps breaking off blow ass BTW
Haha, it is a PIP sensor in there, so its only 1950s tech.
Anywho, it was just a shitty tap. I wasn't using oil, but it was not getting tough at all and then just snapped. That is what I get for being lazy and not wanting to drive all the way down to Sears to get a good tap. I ended up going down there anyway.
whatd you do to clean the tops of the pistons while they were still in the motor? worried about anything being between the cylinder and pistons? an earlier pic looked like there was quite a bit of carbon build up
Yeah, there was quite a bit of carbon buildup. I used a wire wheel cup that you chuck up in the drill. I brought each piston to the top and cleaned it off and also cleaned off the block. Then, I took brake cleaner and sprayed down the cylinder and rotated the engine until I didn't see any crap left behind in the cylinders. I know that there is going to be some crap left over, but I am going to change my oil right away after I start it up to get some of the stuff cleaned out of there.
I have both heads on and torqued and the valvetrain re-assembled. Now I have to finish cleaning up the valve covers and then put the intake manifold back on and put 'er back together. I have more pics that I will put up soon.
MisterCMK;185561 wrote:
Yup, they have that little pinch in them.I have both heads off and the pistons/block surface cleaned up and ready for the heads. I am working on tapping the block holes and will probably bolt the heads on tonight. Fucking autozone shit taps breaking off blow ass BTW
i hope you are not runing a tap:nonono: , you need to use a thread chaser all you are doing is cleaning your threads on the block, you may not see it but taps take a little amount of material off, and thets going to fuck with your torque numbers on your head bolts or studs.
