  4. Disconnecting the "rev limiter"
27 Posts 14 Posters 934 Views
  • JN210J Offline
    JN210J Offline
    JN210
    Would it be a good idea for an automatic? If i did disconnect the governor would it still shift or would the RPM's keep getting higher? I want to disconnect my governor but I'm afraid my car wouldn't shift "seeing as how it's the "rev limiter" " so i guess my main question is "Would my car still shift after disconnecting the rev limiter"?
    Thanks
    *1989 Nissan 300ZX Z31 *
    > DelSlow;262050 wrote:
    > I like the new JN210
      I wouldnt. unless you have a stand-a-lone that can raise your revlimiter.
        Yea, not a good idea.
        • 3_Series3 Offline
          3_Series3 Offline
          3_Series
          Unless you have a built engine and/or standalone, I don't see why you would want to.
          2002 Subaru Legacy
          1993 BMW 325i (sold)
            are you doing this to "top out" higher or rev higher? either way bad idea. you wont make any power reving higher
              ya rev limiters are there for a reason. thats how parts get broken. and more then likely you will just loose power up top, unless you have alot of mods.
              if you are talking about your speed limiter.... why would you want to?
                ^^ They don't know what they're talking about. Get rid of it. You don't need it.
                Once you get it taken care of, set up a video camera and stomp it down in neutral.
                  ^^^ yeah! and spray ether in the intake at the same time! ooo the horsepowa!
                    n00b
                      No, spray nitrous into the exhaust. and then shoot the bottle from a rocket riding away.
                        why the hell would you want to do this anyways?
                        • z31Z Offline
                          z31Z Offline
                          z31
                          Thanks The answer to your question is yes, the transmission will work the same, and No I wont tell you how to do it.
                          Like every one else said, why would you want to raise the red line? :icon_scratch:
                          • ColinC Offline
                            ColinC Offline
                            Colin
                            In many cars that I've come across have rev limiter set to maximize factory settings.
                            Using my swap as an example:
                            makes 240 hp and trq on an N/A 6. redlines @ 6200. Only available in an automatic, and uses 2 indiviual intake manifolds connected by an Iris valve that can open for "power" mode. Has serious breathing and exhaust issues.
                            If i freeze the iris valve open, remove the 6 miles of intake and put on a high flow filter, then run good exhaust, the engine can make power up to 7500 RPM. The reason they limited the reving was because of a shitty exhaust/clearing stroke on the cams plus the poorly flowing exhaust found on all subarus.
                            I'm sure other cars have similar setups...
                            do the research, what are the limitations and why? check, check, data log, then do...
                              yeah, not a cool thing to do. with your stock cams, your car stops making ANY power above 5600. Jason had big ass cams in his with the N/A auto, and it still started falling off over 6500. Waste of time, and i wont tell you how to do it either.
                              Gary
                              • z31Z Offline
                                z31Z Offline
                                z31
                                Here is the stock dyno
                                http://z31.com/faqu/k&n.cone.filter.dyno.stock.na.jpg
                                Disabling the fuel cut (rev limiter) is going to what?
                                • JN210J Offline
                                  JN210J Offline
                                  JN210
                                  Well, I just wanted to see if it was a good idea or not, guess it's not so great. I read off this one forum where this guy took his out, And he showed how, I wasn't really to keen on the idea so i wanted to know what you guys thought.
                                    why would you WANT to do it though, what was your main reasoning for doing it?
                                      You can do it; but, you won't make power up there, and things are probably going to brake.
                                      • ZeroZ Offline
                                        ZeroZ Offline
                                        Zero
                                        when they say "brake" they mean break, and what they are talking about is probably the torque converter. they can explode at high rpms, at least from what i've heard.
                                        You should do other mods first, like different intake manifold, full exhaust, make the stock setup breath better, you'd notice more gains anyway.
                                        Chocolate Rain ;)
                                        MPI conquest
                                        • JN210J Offline
                                          JN210J Offline
                                          JN210
                                          Well my main reasoning for doing it before was to see if i were to get a "power gain" well now i see that the idiot who disconnected his was wrong, i think i will leave it alone. I am however going to build up my VG and turn it into a HP beast, im going to turbo it and while the engine is out of the car im getting a 5-speed trans. (if i can find one cheap) and I'm also going to build up my engine while i have it sitting on the engine rack.
