Bent Valves?
Alright well, the audi is going to need a new engine...I've been thinking about putting in Audi's 2.7 turbo motor, but I'm going to do a little more research and see if it will fit with a little fabricating...I may just put in the regular motor and get an A4 with the money I get for the 6...we'll see what happens...I really liked that A4 out at p10...
Josh
so the motor is done for? what happened?
I have reason to believe that when the gas station tried to time the car, they messed up the outer holes on the camshaft retainers, they got them backwards...so when you line them up like they are supposed to be from the factory, they are totally out of sync, and make everything all screwed up. I could bring it into Valley imports to have them do a timing job, but not only is that 900 dollars, I also have reason to believe that a rod bearing has gone out...when I tried to crank over the engine, I can hear the rod moving on the crankshaft...1100 dollars and I can have a new engine with 78,000 miles on it and that way for the new owner some day, they won't have to worry about any serious trouble with the car.
Thanks, but we are just taking it back. Even if it were the bearings, there's no way I'd be able to do that in a 10x25 storage unit. lol, SO, we are looking for a civic hatch or coupe anywhere from 100-1200. This isn't the forum for that though, so just pm me. Close the thread.
