  4. GM security lug
GM security lug
12 Posts 9 Posters 1.7k Views
  • A
    A
    adog
    Hello. I was wondering if anybody had a security lug for a fourth-gen F-body that I could borrow. I misplaced mine and I need to swap rims. Thanks.
    • A
      A
      adog
      To clarify, I just need to borrow the socket to get the funky lug nut off with.
      • bubbaB
        bubbaB
        Considering as far as I know each car has a different one...that's why they're security lug nuts, no one else can take it off. When I used to work at Fleet Farm, we had a special socket with reverse threads so when this happend we could get them off, however that lug nut is pretty well toast afterwords and it's a pain in the ass...
        • K
          K
          post pics of what it looks like. someone might have something from another application or aftermarket lugs.
          • A
            A
            adog
            Here a a couple of shots of the nut in question. It basically has four regular sides and a part circle.
            • JoelJ
              JoelJ
              www.ebay.com
              • GoodnbuzzdG
                GoodnbuzzdG
                Goodnbuzzd
                Ohhh one of those 😞 id try some sockets that are a lil bigger and [COLOR="darkred"]carefully [/COLOR]try to loosen it, if all else fails dremel the proper socket to match.
                • JoelJ
                  JoelJ
                  wannabe;189474 wrote:
                  www.ebay.com
                  ttt
                  • D
                    D
                    dynotune
                    take a 12 pt socket that is almost the same size and hammer the SOB on the lug nut. You may find someone with the same key, but not real likely. Ruin the 4 "security" lugs and replace with regular ones and never have the problem again.
                    andy
                    DynoTune Speed & Performance
                    Mobile chassis dyno service
                    www.dynotuneusa.com
                    (605) 753-1101
                    • BassplayerB
                      BassplayerB
                      Bassplayer
                      Get one of those Gator Grip sockets. You know the ones with all the pins in the socket so it conforms to any shape. I'd say that'd for really well.
                      1995 GMC Sierra
                      • Turbo5OhT
                        Turbo5OhT
                        Turbo5Oh
                        if ur positive its a gm lug nut, i have the gm master key set at work the only problem is some have went missing over the years so there a good chance i have one but no guarantee
                        but if those dont work i usually just pound a socket on w/ a hammer like andy said
                        • J
                          J
                          jester
                          find any f body and use theirs mine from my 97 z28 worked on both my 2000 and my 2002 z28s. if not go to a dealer im sure they will have them or could get you one.
