  4. GTR
GTR
34 Posts 16 Posters 3.4k Views
  • ParkerP
    ParkerP
    got this off of their official site
    Specifications
    Engine
    • VR-series twin-turbocharged 3.8-liter V6.
    • 480 hp @ 6,800 rpm. 430 lb-ft torque @ 3,200–5,200 rpm.
    • Dual overhead camshafts with variable intake-valve timing.
    • Cast aluminum cylinder block with high-endurance/low-friction plasma-sprayed bores.
    • IHI twin turbochargers, one per cylinder bank.
    • Pressurized lubrication system with thermostatically controlled cooling.
    Drivetrain
    • ATTESA ET-S All-Wheel Drive (AWD) with independent rear-mounted transaxle integrating transmission, differential and AWD transfer case.
    • Rigid, lightweight carbon-composite driveshaft between engine and transaxle.
    • Electronic traction control plus 1.5-way mechanically locking rear differential.
    • Vehicle Dynamics Control (VDC-R) with three driver-selectable settings: Normal (for daily driving, controls brakes and engine output), R-Mode (for ultimate performance, utilizes AWD torque distribution for additional vehicle stability) and Off (driver does not want the help of the system).
    • Hill Start Assist prevents rollback when starting on an incline.
    DisclaimerVDC-R cannot prevent accidents due to abrupt steering, carelessness, or dangerous driving techniques. Always drive safely.
    Transmission
    • 6-speed Dual Clutch Transmission with three driver-selectable modes: Normal (for maximum smoothness and efficiency), Snow (for gentler starting and shifting on slippery surfaces), and R mode (for maximum performance with fastest shifts).
    • Fully automatic shifting or full sequential manual control via gearshift or steering wheel-mounted paddle shifters.
    • Dual clutch design changes gears in less than 0.5 second (0.2 second in R mode).
    • Downshift Rev Matching (DRM).
    • Predictive pre-shift control (in R mode) based on throttle position, vehicle speed, braking and other information.
    Wheels and Tires
    • 20 x 9.5" (front) and 20 x 10.5" (rear) super-lightweight forged-aluminum wheels with Gunmetal Gray finish.
    • Exclusively developed nitrogen-filled Bridgestone® RE070A high-capacity run-flat summer tires, 255/40R20 front and 285/35R20 rear.
    • Tire Pressure Monitoring System (TPMS).
    • Optional exclusively developed nitrogen-filled Dunlop® run-flat all-season tires, 255/40R20 front and 285/35R20 rear (includes Bright Silver wheels).
    Brakes
    • Brembo® 4-wheel disc brakes with 4-wheel Antilock Braking System (ABS), Brake Assist, Electronic Brakeforce Distribution and Preview Braking.
    • Two-piece floating-rotor 15-inch front and rear discs with diamond-pattern internal ventilation.
    • 6-piston front/4-piston rear monoblock calipers.
    Steering
    • Rack-and-pinion steering with vehicle-speed-sensitive power assist.
    • 2.6 steering-wheel turns lock-to-lock.
    Suspension
    • 4-wheel independent suspension with Bilstein® DampTronic system with three driver-selectable modes: Normal/Sport (for automatic electronic control of damping), Comfort (for maximum ride comfort), and R mode (engages maximum damping rate for high-performance cornering).
    • Electronically controlled variable-rate shock absorbers. High-accuracy progressive-rate coil springs.
    • Front double-wishbone/rear multi-link configuration with aluminum members and rigid aluminum subframes.
    • Hollow front and rear stabilizer bars.
    Body/Chassis
    • Exclusive Premium Midship platform with jig-welded hybrid unibody.
    • Aluminum hood, trunk and door skins. Die-cast aluminum door structures.
    • Carbon-reinforced front crossmember/radiator support.
    Back to Top
    Standard Features
    Exterior
    • Wide-beam headlights with High Intensity Discharge (HID) low beams.
    • LED taillights and brake lights.
    • Dual heated power mirrors.
    • Flush-mounted aluminum door handles.
    • Body-color rear spoiler with integrated center high-mounted stop light.
    • UV-reducing tinted glass.
    Audio/Navigation/Performance Monitor
    • Digital Bose® audio system with AM/FM/in-dash 6-CD changer and 11 speakers including dual subwoofers.
    • HDD Music Box system, including hard drive with 9.4 GB for audio storage.
    • MP3, WMA and DVD audio capable. In-dash Compact Flash card reader.
    • HDD-based GPS navigation with touch screen.
    • Driver-configurable performance monitor, developed with Sony® Polyphony, with graphical readouts of vehicle data and driving data displayed on a total of 11 screens.
    • 7-inch WVGA high-resolution color-LCD display for audio, navigation and performance monitor.
    Interior
    • Automatic Temperature Control (ATC).
    • Electronic analog instrument cluster with multi-function trip computer and digital gear indicator.
    • Power front windows with one-touch auto-up/down feature.
    • Intelligent Key system with pushbutton start. Power door locks.
    • Cruise control.
    • Tilt/telescoping steering column.
    • Bluetooth® Hands-free phone system with voice recognition.
    Seating/Appointments
    • Leather upholstered front seats with perforated Alcantara inserts.
    • 8-way power front seats with entry/exit switch for rear-seat passengers.
    • Driver-shaped bucket seat.
    • Dual individual rear seats.
    • Heated front seats.
    • Leather-wrapped steering wheel and shift knob.
    • Drilled aluminum pedals.
    Safety/Security
    • Nissan Advanced Air Bag System (AABS) with dual-stage supplemental front air bags, seat belt sensors and occupant-classification sensor.
    • Driver and front-passenger side-impact supplemental air bags and roof-mounted curtain supplemental air bags.
    • Front seat belts with pretensioners and load limiters.
    • Nissan Vehicle Immobilizer System.
    • Vehicle Security System.
    BlueSRT0483;244555 wrote:
    Trafik Jamz;260984 wrote:
    You are right Parker.
    • ichibankillaI
      ichibankillaI
      You forgot the $80K price tag.
      I wonder how long it'll take for that motor to be available for swaps. I think it's new motor or has it been around for a while? I'm not to hip on motors per say as some of the other guys here.
      • T
        T
        thrash
        Old / New is kind of subjective. It's based off of the modular V6 that's in everything nissan makes... the 350Z, the Murano, etc.
        Gone are the days of the RB series engine... this will be the first V6 GT-R.
        What strikes me as most interesting is the rear-mounted transaxle / transfer case. How are they getting power to the front wheels? Sending it back to the rear-mounted xfer case, and then sending it backup front via a secondary shaft? Seems ridiculous.
        OTOH, that's almost what you need to do if you want the engine back far enough. Audi's have such a long front overhang because the entire engine is AHEAD of the front wheel centerline. On the B8 A4 platform audi actually mounts the clutch at the back of the transmission to save an extra few centimeters of engine-forward-placement.
        I'm disappointed that the RB series engine is gone, and the V6 has been hopped up to be the underpinnings of the new GT-R. The power peak is at 6800 rpm, which is about where it was on an R32 RB engine (according to a quick search...)
        On paper the car certainly looks like the real deal... the brakes are huge, the steering is fast... dual-clutch transmission (like Audi DSG)... and it's still going to have the bomb-ass AWD system. I think it's going to be quite heavy this time around... 3800 lbs ?
          reports have it 10% lighter than a 350z whose curb weight is 3339...so right around 3000 lbs. Basing this off the info I found at Edmunds
          The payoff, claims Nissan, is that while the GT-R's body has 10 percent more surface area than that of the Nissan 350Z, the new car's body-in-white is actually 10 percent lighter overall. And the GT-R has an almost ludicrously slippery 0.27 coefficient of drag (Cd).
          http://www.edmunds.com/insideline/do/Features/articleId=123067
          • 3_Series3
            3_Series3
            3_Series
            Sounds sick.
            2002 Subaru Legacy
            1993 BMW 325i (sold)
            • T
              T
              thrash
              I read that as the unibody, not the overall vehicle 🙂
              • assasainA
                assasainA
                assasain
                pretty bitchen
                • FG2F
                  FG2F
                  FG2
                  I spoke with the Sales Manager at Gateway Nissan yesterday and he said that there will be 1500 per year and they will only be 'pre-sold'. Deposit is $5000 and you get to pick every option (color, interior, etc...). Pretty darn nifty if you ask me!
                  Jason
                  • K
                    K
                    Also, exhaust manifold and exhuast housing on the turbo are casted as one piece. claims that it improves efficiency. Thust making upgrading a costly thing being you need 2 turbos, 2 manis, and 2 new DPs. From what I understand unless ghetto mods are done, that is the only way to upgrade turbos.
                    When one hits the states, the 1st dealer that gets most of this stuff. has a person or 2 on the huge 240/Z car site, Complete inside/outside/underbody pics will be posted. Ill get them on here.
                    I am pretty pumped about this car 0-60 3.5 and 1/4 in 11.7.
                    I bet there will be some sweet aftermarket for these.
                    • JoelJ
                      JoelJ
                      Indash compact flash card reader.... fucking pimp....
                      • ichibankillaI
                        ichibankillaI
                        Plus the HDD Music Box system, including hard drive with 9.4 GB for audio storage.
                        You'd have room for all three F&F movie soundtracks and then some.:D
                        • SPANISH-RICES
                          SPANISH-RICES
                          this car sounds awesome. i wish i was a baller:(
                          • treimcheT
                            treimcheT
                            I wonder fi the drivetrain will be somewhat like a Subaru with the front axles coming right out of the tranny.
                            • grumblecakesG
                              grumblecakesG
                              grumblecakes
                              There is a second shaft coming from the the rear located center diff to the front diff
                              Pic - http://www.autoblog.com/photos/nissan-gt-r/455765/full/
                              VTec, All the lag without the boost, it's like waiting for bad sex
                              • T
                                T
                                thrash
                                No. That's what Audi does also, but that's not something you can do when the transmission, center diff, and rear diff are all at the back of the car.
                                • T
                                  T
                                  thrash
                                  Fascinating. I noticed the offset shaft in one of the other underbody photos, but the exhaust was in the way of the center-shaft, so i didn't see the 2 parallel shafts. I just figured the offset shaft was the driveshaft from the conventional transmission to the conventional rear diff.
                                  • grumblecakesG
                                    grumblecakesG
                                    grumblecakes
                                    Nope
                                    • T
                                      T
                                      thrash
                                      My factory stereo has a dual SD card slots 🙂
                                      (the above picture isn't from my car, but that's the setup I'm running).
                                      It's excellent.
                                      • grumblecakesG
                                        grumblecakesG
                                        grumblecakes
                                        The new GT-R lapped Nurburg in 7min 38sec
                                        http://www.youtube.com/watch?v=uGe_fyhQazg
                                        Not the best vid I know but it does give you a good understanding as to how insane that track is.
                                        Just to put 7:38 in perspective
                                        7:40 - Mercedes-Benz SLR McLaren
                                        7:40 - Porsche 997 Turbo
                                        7:40 - Bugatti Veyron
                                        7:41 - Manthey Porsche GT3 M410
                                        7.42 - Corvette Z06
                                        7:42 - Porsche 997 GT3
                                        7:42 - Ford GT, 550
                                        7:43 - Lamborghini Murcielago
                                        7:44 - Pagani Zonda S
                                        7:46 - Porsche 996 GT2
                                        7:46 - Jaguar XJ220
                                        7:47 - Porsche 996 GT3 RS
                                        7:47 - Ferrari 599 GTB Fiorano
                                        • capitljC
                                          capitljC
                                          capitlj
                                          Yup thats what body-in white means.
                                          Mitch Hedberg wrote:
                                          2004 Impala LS 3.8
