  4. DSM problem. :mad:
DSM problem. :mad:
46 Posts 9 Posters 2.9k Views
    Ran 30 psi , 400+hp , rev to 7200 down the track in 11 sec's
    Stock is fine .....
    Kevin
    SLS
    PS I may have my ol stock wires for sale....
    • F Offline
      F Offline
      frntwhllaser
      I have a 90 plymouth laser that did the same thing. My problem was that my engine leand out and i broke a valve, and that was why my engine was doing that exact same thing. Not to scare you cause it could be something minor like what you are thinking but that is what happened to me. 😮
      Driving and breaking my DSM at least once a month! :D
        bestoneyet
        Hey that happins to you too huh? Join the club.. Its never ending!! If you guys with the broken down dsms want to make a car club go for it! Call it (broke) either way you look at it your car will be broken or your pocket book will be broke!
        Kevin
        sls
          lol @ kevin
            She is running great now but th oil light comes on every time I stop. I read on dsmtuenrs.com that this is OK but just wanted to double check with you guys.
              What does your stock oil pressure guage say at idle?
                At the minimum it is usually at if I sit for a long while once it is warm.
                  Not a good sign. There low normaly stock but not that low.
                    Can I come in and have it checked?
                      There's not really much to check. If you have low oil pressure then there's nothing short of replacing or rebuilding an engine that'll give you oil pressure. I'd just drive it for now and keep a good eye on it. I thought it might just be a bad sensor but if your guage reads low also, than it's a good indication that it's low. Save your pennies for an engine from SLS. They have done countless Jap-spec engine swaps and are reasonable about price.
