  3. Gaming
  4. WTF?
WTF?
12 Posts 10 Posters 1.9k Views
  • JN607J
    JN607J
    JN607
    It's not the cooling I'm worried about, why are the controllers flashing right now when the thing is turned off?
    2004 Scion xA
    Airman First Class Nelson
    • zbrownZ
      zbrownZ
      Luke's brother eats disks too, on the outside edge?
      • JN607J
        JN607J
        JN607
        Yep, and it's getting pretty old...Halo 3 has been replaced once, and now Forza needs to be replaced. It was working just fine last night before I left.
        2004 Scion xA
        • J
          J
          jester
          you really shouldnt use the 360 upright, they are notorious for chewing up discs. also if you need a cooling setup get the one that plugs into the usb port in the back otherwise you face a greater risk for the ring of death.
          • bluejaysB
            bluejaysB
            bluejays
            thats weird the guys at software etc said the one that plugs into the power cord is the better cooling setup
            • JimJ
              JimJ
              Warranty it. Microsoft extended the warranty 3 years....
              • capitljC
                capitljC
                capitlj
                I stand mine up and have had 0 problems.
                Mitch Hedberg wrote:
                2004 Impala LS 3.8
                • JohnWJ
                  JohnWJ
                  JohnW
                  The best cooling set up is one that does not draw power from the xbox 360 at all. i've seen ppl use four 120mm fans powered by an adapter and that drops temps dramatically.
                  The best consumer product right now is the pelican air flo (?) product which runs off the USB ports and also functions as a breakout box giving all kinds of ports. The nyko one will fuck up your shit. Stay away.
                  I say if your 360 needs cooling, you need a new xbox. If it's eating disks, try putting it horizontally, if it still does it, you need a new xbox. call up MS, they are replacing these things left and right, you don't necessarily even need a ring of death to get a replacement.
                  90 Civic DX hatch
                  D16a6/y8 mini me
                  • T
                    T
                    thrash
                    also just fyi -- never change the orientation of the box (flat or upright) while there's a disc in it.
                    the controllers will do the circle-of-green thing when they have a low battery, although having them do that while the box is off is surprising. note that the box also supports "low power mode" now where it will continue downloading and stuff even though its most of the way off..
                    • StangerBanger96S
                      StangerBanger96S
                      StangerBanger96
                      I believe the 3 year warranty only applies to the 3 Red Lights error, everything else is 1 year.
                      There is a well known issue where some of the drives in the 360's have been destroying disks though. I'd be willing to bet if you called Customer Support @ Microsoft they might say "no" at first but you could push enough and get them to say "ok send it in we'll fix it".
