wtb dsm 6 bolt
alright just clearing it up for my self
umm....
(1) NT pistons cant handle more than 8-10psi due to the ring lands being so high on the piston. If you want a higher compression turbo motor....put in higher compression TURBO pistons.
(2) A 7bolt bottom end cannot fit in a 6-bolt block. That whole point of going to a 6-bolt is to get away from the 7-bolt bottom end.
Wiz
pills11.com ;))
Wizard;193221 wrote:
umm....(1) NT pistons cant handle more than 8-10psi due to the ring lands being so high on the piston. If you want a higher compression turbo motor....put in higher compression TURBO pistons.
Wiz
pills11.com ;))
thanks this is exactly what i wanted to know. one more thing is 2g rods/pistons-can they work with 1g crank? and thanks agian for the information.
What happened to the exaust yo!!!! is that for a turbo??? (torbs)
