  3. Wanted Ads
  4. 1g mani.
1g mani.
23 Posts 8 Posters 1.8k Views
  • iluvracingI Offline
    iluvracingI Offline
    iluvracing
    Just wondering if anyone has an UNCRACKED manifold for a 1g dsm NON TURBO that they want to get rid of. Preferably a header but stock will work. Or if anyone knows where I could get one at a reasonable price. Thanx
    96 sunfire se pos!
    2002 v-star 1100-For Sale. (NEED GONE!)
    91 Eagle Talon (hopefully running for auto-x)
    97 F 150
    • GnArKiLlG Offline
      GnArKiLlG Offline
      GnArKiLl
      i think my friend might have one (wizard on here) i think its cracked alittle but i can weld it up real easy
      1976 Chevy K5- lifted beater
        iluvracingI Offline
        iluvracing
        ok... what's tha deal with welding them?? mines cracked pretty nasty and I thought about it but if it's that bad won't that couse problems????
        96 sunfire se pos!
        97 F 150
          if the manifolds are cracked, and cast. you can't weld them. SLS might have one, I know he has lots of DSM parts. if not just buy a header of ebay! lol.
          • GnArKiLlG Offline
            GnArKiLlG Offline
            GnArKiLl
            you can weld them! iv done it befor and it works just fine...
              iluvracingI Offline
              iluvracing
              might try that but mines pretty damn bad!!
              96 sunfire se pos!
              97 F 150
                you can weld them with the correct rod.
                  You can weld cast iron...I believe u need to use nickel rod and really know what you're doing...my grandpa had told me how to do it one time, as he used to weld pretty much anything, but I forgot...
                    are you tig welding or stick. if tig i think some ni-rod 99 filler should work.
                    preheat to a good temp, then weld up crack, then stick it in a bunch of sand to allow it to cool very slowly.
                      I was talking about arc...
                        they also make it in a stick rod.
                        • beachbum_jonB Offline
                          beachbum_jon
                          thought the key to cast was fast and cool, rather than slow and hot. but maybe i am mistaken, my grandpa also told me how to do it along time ago. he use to be a certified welder and as been the head welder in many buildings that have been erected during the 1950's.
                          -John Adams, 1735-1826-
                            well if you do not pre heat the cast and then also try and cool it fast, you can acually hear the peice crack, sounds like little poping noise.
                              beachbum_jon
                              okay then i was mistaken, i knew it was one or the other
                                iluvracingI Offline
                                iluvracing
                                does sls have headers or just the stock manifolds because I looked on ebay and all I can find is stock... I would like to get aftermarket headers at a decent price....
                                96 sunfire se pos!
                                97 F 150
                                  You can weld it with nickel rod. But, it will not last and start to crack right from where the weld ends. Been there and done that.
                                    iluvracingI Offline
                                    iluvracing
                                    thanks man. I got a friend that can weld like theres no tomorrow and might have him weld it up for the time being but wanna know if I can get a nt header somewhere for a decent price... don't wanna spend alot of money!!!!
                                    96 sunfire se pos!
                                    97 F 150
                                      if you drill small holes right were the crack starts and stops it should never crack again if welded properly. you just need to make sure you stoped the crack from being able to start up again.
