  4. 91 explorer parts
91 explorer parts
12 Posts 5 Posters 926 Views
    It'll work. Let me know if you need help with anything, the Explorers are easy to work on. If you are picking up a parts truck, let me know. I need a few things. Look for one in a dark metallic red if you can. 😄
    • lord_deastofactL Offline
      lord_deastofact
      well I don't know if your interested cmk, but I had thought of if someone that knew more about the tranny and 4x4 parts wanted to swap them for me, they could have the rest of the one i'm buying, in good condition cept the engine is alittle f'd guy ran it out of water and overheated it.
      Minute ricer!
      • BookemB Offline
        BookemB Offline
        Bookem
        Hey Chris, do the exploder's have the dana 44 front split beam or whatever they call it? If so I would like to check out some parts as well.
        Legacy GT
        Gmc Suburban
        Hallorann: Fargostreet?
        Hallorann: No, I ain't.
          If the engine was overheated the head could have warped as they do that easily.
          I would definitely be interested. PM me and we'll talk.
            They have a D35 TTB front end. You would want to look for an F-150 to have the D44 TTB
            • dubbsyD Offline
              dubbsyD Offline
              what 4 wheel drive parts do you need swapped?
                lord_deastofact
                I am honestly not sure, but when it's cold and i turn on 4wheel drive I get a random clunk like it is slipping, not sure if it's the hubs or something else, I don't know very much about the innerworkings of 4wheel. but only the parts that would fix that, I have no idea how hard it would be, any thoughts?
                Minute ricer!
                  i thought all 4wd trucks clunk some going into 4wd?
                    lord_deastofact
                    not going in, when I'm driving once it's on. so I never use it. not in any pattern that would tell me if it was worn in one spot, but rather randomly, it will not do it for 8 blocks then do it a bunch in half a block. I am not sure what it is, but figured it was bad and just didn't use it.
                    Minute ricer!
                    • dubbsyD Offline
                      dubbsyD Offline
                      very possibly the hubs slipping. Those had an issue with not fully engaging (my 94 did and I believe Chris's did so he now has Warn manual hubs). The hubs are supposedly rebuildable but I'd have to find the link here with the bearing info (cheaper to buy the bearing from somewere like bearings and drives vs getting the kit from Ford).
                        Probably the hubs. I have an extra set of auto hubs or you can convert to manuals like I did. Well worth it to convert.
