  4. DSM Heat
DSM Heat
21 Posts 7 Posters 2.5k Views
  • -GSX-Falcon-
    -GSX-Falcon-
    -GSX-Falcon
    Jim wrote:
    cardboard isn't going to help at all.
    my DSM's heat used to be fuckin awesome, i'd turn the car off, come back 30 min later and it'd still be warm... then a month or two ago, it just stopped working well.
    here's what i do... drive it normally till it gets up to temp, and them i stomp the gas and boost alot and my heat gets warm 🙂 i'm a ricer.
    anyway, they have heated seat covers at target you should look in to it 🙂
    Yeah it may come to somekind of plug into the cig lighter heater or something.
    92 GSX Automatic -Manual Cams, Injectors, ECU -Big 16g -Turboback Exh -Ported Evo Manifold -Ported 2g o2 -MBC -JDM 4g63 -Walbro 190 -3" Intake
    • torbsT
      torbsT
      i just drove mine tonite on the interstate, held normal temp and good heating...THEY GHETTO BEAST CAN DO SOMTHING YOURS CANT!!! lol...or maybe my thermostat just doesnt work lol...
      • torbsT
        torbsT
        and may i say this is my first time EVER that i got to drive my car...its been sittin since sept...wow boost feels so good
        • -GSX-Falcon-
          -GSX-Falcon-
          -GSX-Falcon
          Maybe mine is just wayyy more effiecent so less of my power is converted to heat.....yes that has to be it 😛
          • torbsT
            torbsT
            ok, u go have your more efficient and less heat while im nice and warm in my heat 😄
            • -GSX-Falcon-
              -GSX-Falcon-
              -GSX-Falcon
              and now i cry 😞
              • wesholeW
                wesholeW
                Geez guys just try changing the t-stat. they will still function but will sometimes stay stuck open enough not to create enough heat from the engine to heat your heater core. Jim, if it used to heat good and doesn't now, that's probably it. If not, try to back flush your heater core. It's not hard to do. Both my previous DSM's heated excellent even in sub zero conditions.
                • wesholeW
                  wesholeW
                  Oh yeah, Also make sure that the coolant level is up to par. If it isn't, you'll have an air pocket in your cooling system and it'll end up in your heater core resulting in a no-heat situation also.
                  • amichezeA
                    amichezeA
                    mine works just fine. takes maybe 5 minutes to get warmed up and then the heat works great. i have a big problem with the windows getting all icy and fogged over while im driving though.
                    Fargostreet Trolls wrote:
                    i must be stupid
                    • PSiedTSiP
                      PSiedTSiP
                      god i wish i had heat in my dsm 😞
                      spanish-rice;237125 wrote:
                      • JimJ
                        JimJ
                        My coolant is full, and we made sure to get all the air out....
                        Would a flush make any difference?
                        • -GSX-Falcon-
                          -GSX-Falcon-
                          -GSX-Falcon
                          Make sure your vents are open I had a big prob with that too. Opening the vents helped alot.
                          • wesholeW
                            wesholeW
                            If your heater core is getting plugged in the least bit, YOU BET IT WILL!! just backflush the heater core itself.
                            • JimJ
                              JimJ
                              Bought a new motor anyway, so no point in doing it now
                              • wesholeW
                                wesholeW
                                just do it when u pull the engine out soooo much easier then.
                                  What vents?
                                  I have no problem heating up in my DSM. Problem I have is the damn dipstick keeps popping out coating my engine in nice oil. Don't worry Weshole I am going to pinch the dipstick tube and do the thing with the oil valve since I am home now back in the great WI until the 7th.
                                  • PSiedTSiP
                                    PSiedTSiP
                                    my dipstick popped when my car was stock...and i got pulled over at that same time so the cop let me off cause i told him i thought i just blew my car up and i just got it from the shop lol 🙂 oh yeah and i only had a turbo for exhaust and he offered his flashlight under the hood lol
                                      Thath must have been nice just having a turbo for the exahust. No boost lag whatsoever.
                                      Did you pinch the tube in order to stop it?
                                      • PSiedTSiP
                                        PSiedTSiP
                                        it only that one time...more smoke than i ever wanna see from my car again...scared the hell out of me let me tell ya...it was right after i got the new motor running so i was just taking it for a test drive before it was modding time...
                                        there was no lag anyway...it was a 13g strapped on there and that sucker practically spooled at idle...ask jeremy how it was against his 14b 🙂
