  3. Track Talk
  4. auto x!!
auto x!!
170 Posts 30 Posters 24.1k Views
  • itRfanI Offline
    itRfanI Offline
    itRfan
    ^^^^werd do it freitag
    -weshole
    • Gundar1G Offline
      Gundar1G Offline
      Gundar1
      07 si, stock but will have springs and hopefully header, exhaust.
      maybe 94 hatch if its running....
      EVO
        Is there an AWD mini-suv class in auto-x? If so, I may be purchasing a vehicle I'd run with (just for fun of course...and no, its not my Murano)
          mmmm. depends on the size of the vehicle you would have. it would go into the stock class.
          but there are some hieght, wheel base limitaions.
          frietag, for the money you spend on all those interior peices you are just wasting money. stich weld the interior, and put in a cage and a front STB and call it good.
            DrifterExtreme;194908 wrote:
            freitag roll cage? cheap and WAY more stiff then any bolt on bar you could buy
            why not cage it and use all the bars!!!!!
              ^you will just waste money. a roll cage is the biggest stiffning mod you can do. putting a front STB will brace up the front end. and depeing on what they make there are some that go from frame to fraim on the rears by the tail lights
                if you have a good cage there is no need for 47 connecting bars, going from all over the car to random spots. waste of money... lol
                as faber has said get a stb aswell, and if you insist on a rear stb just have the person who is welding in the cage have the rear down bars go into the strut tower area and when he welds in the base plates he can add a rear bar that will connect the strut towers. way stiffer then any aftermarket bolt on stb.
                  Wheelbase 105.9
                  Height 65.3
                  • tntmstrT Offline
                    tntmstrT Offline
                    tntmstr
                    tjamz;194949 wrote:
                    Wheelbase 105.9
                    Height 65.3
                    sounds FJ-ish
                    Jason Christopherson
                    Store Manager
                    Tintmasters
                    Fargo, ND (701)239-TINT
                    www.tintmasters.net
                      Nope... I haven't bought it yet, but I'm leaning towards a Nissan Rogue, but I have a Murano already, so I may say screw it and get a Titan instead....we'll see
                      • black2gB Offline
                        black2gB Offline
                        black2g
                        the rogue's are fun. I got to drive a bunch of them when i worked at Nissan. I think the only trans you can get is the cvt( i could be wrong). Nissan is still having alot of the cvt's go bad. i would recommend the extended warranty.
                        1995 Eagle Talon
                        2000 Doge Neon
                        1974 Porsche 914
                          chucks livin on the edge!
                            You are right, it is CVT...but CVT w/ paddle shifters at least.
                            I've had very good luck w/ my CVT in my Murano. Beside, I very seldom ever keep a vehicle long enough to need extended warranty.
                            • M Offline
                              M Offline
                              musthavemuzk
                              and another thread i was in i was told to keep it on topic.
                              did anyone read this one?
                              WTF?
                              anyways
                              yes i want to autoX next year. just gotta see about money and such.
                              first love though is the 1320.
                              Monty
                              14.59 at 94.85 still stock
                              www.pbase.com/musthavemuzk
                                It really wasn't all that off topic, I asked about classes for small SUV's, the response was made, someone commented on the vehicle and its transmission, I stated it had paddle shifters, and we are now back on topic
                                  musthavemuzk;195137 wrote:
                                  ....the 1320.
                                  boring...
                                  • M Offline
                                    M Offline
                                    musthavemuzk
                                    i hear that all the time.
                                    BUT
                                    to each their own.
                                    autoX looks a blast. so i hope to give it a go this next year.
                                    my car is by no means a car made for it, but will still give it a go.
                                    Monty
                                      BUT
                                      to each their own.
                                      Monty
                                      Your car is a lot closer to an autocross style car then mine and i still might try it. Who knows, my car won't be good for it but it is about fun right....
                                      • M Offline
                                        M Offline
                                        musthavemuzk
                                        yes it is about fun.
                                        something i have read about autoX is that is helps you drive better evenif you are not the fastest out there. as you have to see better. you have to learn your car to do your best.
                                        then the next event is dif course and you have to do it all over again.
                                        Monty
                                        • R Offline
                                          R Offline
                                          revolutionz_s13
                                          I will be all for some auto-x next year. Hopefully we can get some up in GF again....I already have a nice collection of parts for next year, and it just keeps getting bigger, except i'm running out of space in my bedroom to store them all.... 😄
                                          > MisterCMK;207559 wrote:
                                          > Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
