DSM Timing Belt Question
awd95mn;202936 wrote:
Well my water pump started to leak, so I am going to replace the water pump, tbelt, tbelt tensioner, and pulleys. Will probably also replace BS belt and tensioner/pulleys.
if there is nothing wrong with the tensioner or pullys i would just leave them. they last forever in most cases.. just get and oem waterpump, timing belt, bs belt and you will be just fine -
OEM everything..........belt included (some good aftermarket belts area available, but they are double in price...they are just as good or better than OEM, however...DO NOT go with some random belt from an auto parts store...I learned that the hard way)...is risking your whole motor/time really worth an extra $100-200 in parts?
go with a greddy belt
Do NOT go with a greddy belt. A few cases of the things falling apart!!
If you're going Kevlar go with Power Enterprise. Otherwise, just go OEM. OEM Everything, NO Topline, NO contitech(or wtfever).
You GET what you pay for!
JNZTuning.net has pretty good prices on OEM Mitsubishi timing parts(Cheaper than most places around here, or on the net for that matter). If you can't find it on the site, call them up, don't be scurred, they will help you figure out what you need and won't alienate the shit out of you. A+ guys there.
Well my water pump started to leak, so I am going to replace the water pump, tbelt, tbelt tensioner, and pulleys. Will probably also replace BS belt and tensioner/pulleys.OEM for anything important on most cars unless something else has been PROVEN consistently better, as a general rule.
I know practically nothing about DSMs in general - so I'm gonna have to ask -
- what the hell is the BS belt for? keeping down all the BS that comes along with owning a DSM? =D
Ya I ordered all the parts off mitsubishiparts.com today, I have used them before and they have really good service, and were $20 cheaper than anywhere else. I will tear it apart this weekend and hopfully get it all put together a couple weeks after that.
