  4. Pontiac gurus..or someone smarter than me...
28 Posts 14 Posters 1.4k Views
  • MisterCMKM
    MisterCMKM
    94NDTA;207430 wrote:
    They are probably both related. Fix the wire/sensor/wheel bearing.
    werd, thats what I'm thinking.
    thrash;315544 wrote:
    Ford is back :)
    • 94NDTA9
      94NDTA9
      itRfan;207431 wrote:
      Any ideas on how to fix this guys???
      I just told you.
      • Turbo5OhT
        Turbo5OhT
        Turbo5Oh
        ah shit my crystal ball is in the shop getting fixed right now
        well i guess u'll have to do it the hard way.
        get a scan tool on it, find out what wheel is at fault, and what fault it is.
        then get back to us.
        it is a complete guessing game untill u know what fault and what corner it is
        • itRfanI
          itRfanI
          itRfan
          New info...My fiance told me that when she was on interstate they never came on...but today with me driving in town they came on???? Oh and i will have to do that turbo50h!! Thanx for the advice guys i appreciate it....FABER!!!! you got a scan tool if im not mistaken...Can you hook me up???
          -weshole
          • RidinRailsR
            RidinRailsR
            its a gm....they all do that in the winter...well they're all supposed to..
            the abs dont work unless they need to, like in winter, when its slippery. Thats why its on .
            otherwise, the abs sensor is bad, or disconnected, or a loose connection..
            • 99civic9
              99civic9
              99civic
              ok i may be way off but when my pontiac did that it's because my alt. or battery was going out after a while it got worse then my car just died....... pontiacs FTMFL!!!!!
              2000 civic SiR - jdm sickness
              • 2gTSIGUY2
                2gTSIGUY2
                2gTSIGUY
                abs sensor indeed. check for bad connections like this one.
                • itRfanI
                  itRfanI
                  itRfan
                  Alright im gonna have to that..again thanx guys
                  -weshole
                  • wesholeW
                    wesholeW
                    IF it is the sensor (which unless a wire is broke I'm sure it is). Plan on putting a wheel bearing in there as it is a sealed unit and not serviceable seperately front or rear.
                    • itRfanI
                      itRfanI
                      itRfan
                      Yea we just replaced the the passenger side wheel bearing last spring....God these pontiacs are JUNK!!!
                      -weshole
                      • wesholeW
                        wesholeW
                        Dont blame pontiac or Gm for that matter. ALL vehicles have their issues. And no matter what you drive, your bound to encounter them.
                        Tell ya what, leave the car as is. Put the keys in the ignition, put the signed title in the glove box, and back away very slowly. Gimme a holla and I'll come up there and dispose of the problem for you discreetly. I wont even charge you for it. Consider my service a gift from one friend to another.
                        • bubbaB
                          bubbaB
                          Bring it down to the farm...we'll give it a proper send off in a blazing glory of AK and AR rounds...maybe a cannon or 2...
                          • z31Z
                            z31Z
                            z31
                            • Cura86C
                              Cura86C
                              Cura86
                              Pontiacs(more like the grand prix/ams) burn through wheel bearings so fast. But if the abs light is on it is most likely a wire. Still if you are in there throw a hub in even if its a china one.
                              www.RoadsideSalvage.com
                              • K
                                K
                                Call me tomorrow. I do not know how indepth our scan tool will do for ABS stuff, its not the pontiac one. But its not your average one.
                                You know where my shop is, I'll see what we can do. Most likely is an ABS sensor. GPs HATE them. If is a wheel bearing you would be able to hear it, like on my Jeep. We can put it on the hoist and such.
                                • L
                                  L
                                  lglarum
                                  Most likely a wheel speed sensor is either bad or the connection is corroded. You can try to clean the connections and see if that goes away or take it to someone who has a Tech 2 scanner to pull what sensors are defective.
                                  2000 SSEi
                                  www.bonnevilleclub.com
                                  • K
                                    K
                                    I pulled the codes. It was the RF wheel speed sensor.
                                    I also pulled a code for the Fan relay. MIL has been on since car hit a deer. They said they tried to fix it, gut keeps coming back.
                                    • itRfanI
                                      itRfanI
                                      itRfan
                                      yeah faber it came on right as i pulled outta your shops driveway...lol
                                      -weshole
