  4. Pontiac gurus..or someone smarter than me...
28 Posts 14 Posters 1.4k Views
  • 2gTSIGUY2
    2gTSIGUY2
    2gTSIGUY
    abs sensor indeed. check for bad connections like this one.
    • itRfanI
      itRfanI
      itRfan
      Alright im gonna have to that..again thanx guys
      -weshole
      • wesholeW
        wesholeW
        IF it is the sensor (which unless a wire is broke I'm sure it is). Plan on putting a wheel bearing in there as it is a sealed unit and not serviceable seperately front or rear.
        • itRfanI
          itRfanI
          itRfan
          Yea we just replaced the the passenger side wheel bearing last spring....God these pontiacs are JUNK!!!
          -weshole
          • wesholeW
            wesholeW
            Dont blame pontiac or Gm for that matter. ALL vehicles have their issues. And no matter what you drive, your bound to encounter them.
            Tell ya what, leave the car as is. Put the keys in the ignition, put the signed title in the glove box, and back away very slowly. Gimme a holla and I'll come up there and dispose of the problem for you discreetly. I wont even charge you for it. Consider my service a gift from one friend to another.
            • bubbaB
              bubbaB
              Bring it down to the farm...we'll give it a proper send off in a blazing glory of AK and AR rounds...maybe a cannon or 2...
              • z31Z
                z31Z
                z31
                • Cura86C
                  Cura86C
                  Cura86
                  Pontiacs(more like the grand prix/ams) burn through wheel bearings so fast. But if the abs light is on it is most likely a wire. Still if you are in there throw a hub in even if its a china one.
                  www.RoadsideSalvage.com
                  • K
                    K
                    Call me tomorrow. I do not know how indepth our scan tool will do for ABS stuff, its not the pontiac one. But its not your average one.
                    You know where my shop is, I'll see what we can do. Most likely is an ABS sensor. GPs HATE them. If is a wheel bearing you would be able to hear it, like on my Jeep. We can put it on the hoist and such.
                    • L
                      L
                      lglarum
                      Most likely a wheel speed sensor is either bad or the connection is corroded. You can try to clean the connections and see if that goes away or take it to someone who has a Tech 2 scanner to pull what sensors are defective.
                      2000 SSEi
                      www.bonnevilleclub.com
                      • K
                        K
                        I pulled the codes. It was the RF wheel speed sensor.
                        I also pulled a code for the Fan relay. MIL has been on since car hit a deer. They said they tried to fix it, gut keeps coming back.
                        • itRfanI
                          itRfanI
                          itRfan
                          yeah faber it came on right as i pulled outta your shops driveway...lol
                          -weshole
