  4. Brake problems...need help/ideas
15 Posts 8 Posters 680 Views
    im tellin ya. wheel off, drum hammered off, clean that shit up and youll be fine
      Shouldn't need to hammer the drum off. Use the star wheel to retract the brake shoes. Take a look in there and see what is siezed up. Also check the e-brake cables
        his e-brake doesnt work, hasn't for ever.
        I am pretty sure the shoes are froze to the drum.
          Yea, i had to do this on one of my old cars. And i have changed brakes in a parking lot before too.
          Or you could put on disks.
            Disc conversion is for the other car...not gonna swap for a car that's getting sold anyways (especially since i'm robbing the front DA brakes from it). I'll probably tear it apart tonight after class. The one time I decide to leave all my tools at home instead of keeping them up here is when I need them, lol.
              its been a while since i looked at the drums on the civic but isnt the star wheel on the inside? i dont think you can adjust from the outside on hondas. i could be very wrong tho.
                There should be an access slot/hole on the back side. There is usually a rubber plug that you need to remove.
                  yea usually i guess ive just never seen it... or looked for it for that matter
                  • CRX_CivicC Offline
                    CRX_CivicC Offline
                    CRX_Civic
                    hammer method :icon_thumright:
                    • BookemB Offline
                      BookemB Offline
                      Bookem
                      It's possible the wheel clyinder pistons are hyperextending due to the brakes being worn out too much, combined with the star adjuster not adjusting . When that happens it usually drags the brake a little while after using them, or could stay locked up.
                      Legacy GT
                      Gmc Suburban
                      Hallorann: Fargostreet?
                      Hallorann: No, I ain't.
                        ^ that's what I was thinking...hammered the fuck outa the drum and tried prying...wouldnt budge. Didnt have a small enough wrench to open the bleeder screw, probably gonna try that tomar...
