  4. its almost....
its almost....
154 Posts 28 Posters 13.7k Views
  • zbrownZ
    zbrownZ
    turn down the wire speed just a hair and the spatter will disappear, or just trigger it
    that is the perfect size welder to be doing what you are
    what is that 3.5 or 4??
    • K
      K
      ^3inch
      • JoelJ
        JoelJ
        Zach, my wire couldn't go any lower(3.5/10) without getting continuous burnback. I know how to set a welder ...and It's 3 inch.
        • zbrownZ
          zbrownZ
          obviously.........
          • F
            F
            fanaticrockford
            What model welder is that?
            Looks like the one I'm looking at purchasing Lincoln sp135t
            The welder is perfectly capable of the job but not with that tiny ass long extension cord.
            • ParkerP
              ParkerP
              the cord is bigger than it looks
              BlueSRT0483;244555 wrote:
              Trafik Jamz;260984 wrote:
              You are right Parker.
              • RexwagonR
                RexwagonR
                Looks good parker. Cant wait to see that thing in person
                • JoelJ
                  JoelJ
                  lol, the manual says it will penetrate 3/16... so its not made for that. If either of you wanna come make better welds, your welcome to.
                  • F
                    F
                    fanaticrockford
                    I'm a beginner welder and can tell you your much better then me Joel. I have been doing a lot of research especially with the Lincoln sp135 which that welder looks to be. So what welder is that?
                    All I'm saying is that your losing a lot of current with that long extension cord. It may be adequate gauge like parker says but where is it plugged into? I suppose to an outlet? How far away is the outlet from the fuse panel and with what gauge wire?
                    I can guarantee you if the welder was plugged directly into the fuse panel or to a outlet close by those welds would be better.
                    • zbrownZ
                      zbrownZ
                      I would if i was there
                      lol, you do realize that means 3/16" full penetration from one side with no joint preparation...............
                      Good thing you are going for for 100% melt-through on a 1/4" flange when you are welding a 16 ga. tube to it 😕
                      .little bit of difference going from production welding where coarse machine parameters are set and you are in charge of electrode manipulation only............. don't get more and more into this, the welds look fine, all i am saying is that the machine was not set 100% properly and it wasn't
                      • JoelJ
                        JoelJ
                        good call, never thought about it. Yes its a 135t, if you wanna come take a look at it, you are more than welcome...
                        • 91nbtsi9
                          91nbtsi9
                          Joel;211044 wrote:
                          no, were attempting to penetrate a 1/4 inch flange with a 135 amp welder. why do you ask about flux core? what characteristics make it look like it was made with a flux core welder?
                          Because of the spatter. From my experience....there should never be spatter like that from a MIG unless you have something set wrong or are out of gas, heh.
                          • JoelJ
                            JoelJ
                            zbrown;211102 wrote:
                            Good thing you are going for for 100% melt-through on a 1/4" flange when you are welding a 16 ga. tube to it 😕Im not going for full penetration, just getting some color on the other side of the flange. And as I understand from my welding experience, I should be penetrating both workpieces as much as possible... Less penetration, less stength. Especially with 2 metals with such different thicknesses...
                            • JoelJ
                              JoelJ
                              • JoelJ
                                JoelJ
                                FYI, I'm not a production jig welder. I set my own machine and change my settings on a regular basis, out of position, mostly V. down and overhead welding
                                • ParkerP
                                  ParkerP
                                  arguing about welding makes me lol
                                  • FG2F
                                    FG2F
                                    FG2
                                    All I read into all this was:
                                    Zach is pointing out bad penetration
                                    Joel went to school to learn about penetration and thinks he is fully penetrating properly
                                    Nate doesn't think there should be as much splatter from the said penetration
                                    Then it gets into machines and settings to make perfect penetration....
                                    bunch of homo's 😉
                                    • MisterCMKM
                                      MisterCMKM
                                      Some random guy arguing about the outlet location and such makes me lawl. n00bs
                                      thrash;315544 wrote:
                                      Ford is back :)
                                      • bubbaB
                                        bubbaB
                                        Joel;211112 wrote:
                                        And as I understand from my experience, I should be getting penetrated both ass and mouth as much as possible... Less penetration, less fun. Especially with 2 cocks of such different thicknesses...
                                        Hmm... I think this was more what he was going for....
                                        • K
                                          K
                                          OMG ROFL, my dad is in the back shop and heard me loling!
