its almost....
zbrown;211102 wrote:
I would if i was therelol, you do realize that means 3/16" full penetration from one side with no joint preparation...............
Good thing you are going for for 100% melt-through on a 1/4" flange when you are welding a 16 ga. tube to it
.little bit of difference going from production welding where coarse machine parameters are set and you are in charge of electrode manipulation only............. don't get more and more into this, the welds look fine, all i am saying is that the machine was not set 100% properly and it wasn't
FYI, I'm not a production jig welder. I set my own machine and change my settings on a regular basis, out of position, mostly V. down and overhead welding
And as I understand from my welding experience, I should be penetrating both workpieces as much as possible... Less penetration, less stength. Especially with 2 metals with such different thicknesses...
All I read into all this was:
Zach is pointing out bad penetration
Joel went to school to learn about penetration and thinks he is fully penetrating properly
Nate doesn't think there should be as much splatter from the said penetrationThen it gets into machines and settings to make perfect penetration....
bunch of homo's
Joel;211112 wrote:
And as I understand from my experience, I should be getting penetrated both ass and mouth as much as possible... Less penetration, less fun. Especially with 2 cocks of such different thicknesses...Hmm... I think this was more what he was going for....
Hahaha pwnt.
FG2;211123 wrote:
All I read into all this was:Zach is pointing out bad penetration
bunch of homo's
grip -
