  3. Run Your Mouth
  4. Joels properly set welder VS Mine........
54 Posts 23 Posters 5.4k Views
    whats with the personal attacks? Who looks bad now. Why don't you critique those ones zack, what it set wrong? too much spatter?
      Good job, those look nice. Its a real benefit to work with nice clean metal with good gaps and stuff, man i hate welding on rusty old farmer shit.
      BTW, good story here. One day i had to weld in this chemical tank, aluminum with the spool gun right. Anyway theres only a big enough hole to get your torso through, and it was a 16ft tank, welding was on the baffles inside. I had to hang the from forklift by my feet while holding the gun and cables, 20ft in the air and get set into this thing. Aside from the stink, the shit burned your skin as it was in direct sunlight and about 90 degrees and humid that day. I thought, WTF is this shit anyway, especially getting jerked around on this fuckin forklift you know? So i had to do this shit for 30-40 minutes and it sucked balls, but i ended up making a couple hundred in cash on the deal.
      So, if you ever think you have it rough, think again
        thrash
          thrash;211312 wrote:
          LOL!
            Hey parker I just remembered something, that spool of wire was on its last leg, the un-evenness(word?) of wire coming out could have caused the spatter...
              Hmm... looks like the typical Joel gets pwned and he keeps running his mouth making him look dumber and dumber... U can talk all you want, you're just gonna keep getting more and more pwned...
                typical brandon, throwing his 2 cents in threads where he doesnt belong, just to be cool.
                  Yep, u gonna get all butthurt and cry about it now or what... his weld > your weld fucking deal with it... Now Joel's gonna try to say I dont know shit about welding cause I never went to a little class to get certified and do it for a living...
                    I think what Zac was trying to point out here is that the one particular weld that you made didn't turn out very well Joel. Perhaps it was the lack of familiarity w/ that particular welder or whatever. What Zac was trying to point out (successfully IMO) was that the welder you used was enough of a welder for what you were doing and that welds can be done w/o the spatter that happened to you. Your other welds look good Joel (the ones from work) which leads me to believe that the settings were off a bit....which is exactly what Zach was trying to prove as well.
                    • itRfanI Offline
                      itRfanI Offline
                      itRfan
                      jesus i miss alot when i work nights....this blows. By the way why are these two fighting about welding? Isnt there something better to do? It is obvious that zachs welding owns joel but joel hasnt had much time welding if im correct? I cant weld for shit but really wanna learn how in fact i think this summer or winter i will do the daves welding for two weeks or see what they got going on up at the skills and technology on 19th.
                      -weshole
                      • slow90gsxS Offline
                        slow90gsxS Offline
                        slow90gsx
                        practice makes perfect.
                          The only reason i posted up is because you posted the pics of your welds and i got the feeling that you thought that was the way they are supposed to look.
                          I didn't want other members who aren't familiar with welding to think that was the case
                          The reason i pulled out some shots at you is because you were calling me out for a shady shit, and that simply wasn't the case
                          I welded those 3 beads and that was all, its not like i welded on a scrap piece 5 mins, then came ran a little bead, then set the welder differently for the different technique, run some more on a scrap piece, weld a little bead ect....
                          I never touched the welder between each weld; the settings are the exact same for each, and i pointed out the vertical down bead could of used a little bit slower wire speed
                          Ill make a vid start to stop if anyone here doubts my methods
                          • 91nbtsi9 Offline
                            91nbtsi9 Offline
                            Joel, why did you post a picture of the bird poop weld in the first place? I would have left that and hoped nobody ever saw it. You know it wasn't good because your other welds look good from your work pictures. My high school welding teacher said it best...you can teach a monkey to MIG weld. Just give it up and admit it wasn't a great weld..;)
                            • ColinC Offline
                              ColinC Offline
                              Colin
                              You can both weld better than I can. Damn.
                                man you guys are brutal... i could care less what exhaust welds looks like, there under a car... and as loing as they dont crack, i dont give a shit.....
                                  triple posting FTL...oh and the welds are...alright...lol
                                    it wasnt a shitty weld though, The penetration was good, I am happy with the weld given the equiptmentused. I posted to as a picture of parkers exhaust in his exhast thread.
                                    • Sweet-WRX-LovinS Offline
                                      Sweet-WRX-Lovin
                                      My welds can beat up your welds.
                                      One time...
                                        i was waiting for someone to say that....
                                          to play devils advicate... i want pictures of you welder zac :rolleyes:
