  3. Run Your Mouth
  4. Joels properly set welder VS Mine........
54 Posts 23 Posters 5.4k Views
    bubba;211327 wrote:
    Hmm... looks like the typical Joel gets pwned and he keeps running his mouth making him look dumber and dumber... U can talk all you want, you're just gonna keep getting more and more pwned...
    typical brandon, throwing his 2 cents in threads where he doesnt belong, just to be cool.
      Yep, u gonna get all butthurt and cry about it now or what... his weld > your weld fucking deal with it... Now Joel's gonna try to say I dont know shit about welding cause I never went to a little class to get certified and do it for a living...
        I think what Zac was trying to point out here is that the one particular weld that you made didn't turn out very well Joel. Perhaps it was the lack of familiarity w/ that particular welder or whatever. What Zac was trying to point out (successfully IMO) was that the welder you used was enough of a welder for what you were doing and that welds can be done w/o the spatter that happened to you. Your other welds look good Joel (the ones from work) which leads me to believe that the settings were off a bit....which is exactly what Zach was trying to prove as well.
        • itRfanI Offline
          itRfanI Offline
          itRfan
          jesus i miss alot when i work nights....this blows. By the way why are these two fighting about welding? Isnt there something better to do? It is obvious that zachs welding owns joel but joel hasnt had much time welding if im correct? I cant weld for shit but really wanna learn how in fact i think this summer or winter i will do the daves welding for two weeks or see what they got going on up at the skills and technology on 19th.
          -weshole
          • slow90gsxS Offline
            slow90gsxS Offline
            slow90gsx
            practice makes perfect.
              The only reason i posted up is because you posted the pics of your welds and i got the feeling that you thought that was the way they are supposed to look.
              I didn't want other members who aren't familiar with welding to think that was the case
              The reason i pulled out some shots at you is because you were calling me out for a shady shit, and that simply wasn't the case
              I welded those 3 beads and that was all, its not like i welded on a scrap piece 5 mins, then came ran a little bead, then set the welder differently for the different technique, run some more on a scrap piece, weld a little bead ect....
              I never touched the welder between each weld; the settings are the exact same for each, and i pointed out the vertical down bead could of used a little bit slower wire speed
              Ill make a vid start to stop if anyone here doubts my methods
              • 91nbtsi9 Offline
                91nbtsi9 Offline
                Joel, why did you post a picture of the bird poop weld in the first place? I would have left that and hoped nobody ever saw it. You know it wasn't good because your other welds look good from your work pictures. My high school welding teacher said it best...you can teach a monkey to MIG weld. Just give it up and admit it wasn't a great weld..;)
                • ColinC Offline
                  ColinC Offline
                  Colin
                  You can both weld better than I can. Damn.
                    man you guys are brutal... i could care less what exhaust welds looks like, there under a car... and as loing as they dont crack, i dont give a shit.....
                      triple posting FTL...oh and the welds are...alright...lol
                        it wasnt a shitty weld though, The penetration was good, I am happy with the weld given the equiptmentused. I posted to as a picture of parkers exhaust in his exhast thread.
                        • Sweet-WRX-LovinS Offline
                          Sweet-WRX-Lovin
                          My welds can beat up your welds.
                          One time...
                            i was waiting for someone to say that....
                              to play devils advicate... i want pictures of you welder zac :rolleyes:
                                its an old school ESAB
                                id take the one you were using any day over this
                                  • they're
                                  • long
                                    ^You missed don't(also more professional as do not)
                                      No, I did not miss it. I was simply correcting his pathetic spelling and word choice.
                                        ^^^ umm no one cares
                                          Get back in your hole
