12 injector setup
Damn nice craftmanship on that intake. Where does the "Danger to Manifold" sensor go?
Running straight E98 you really dont need the intercooler. I have watched quite a few cars setup with methanol and ethanol, and on cool days the intake will frost up. This is very common on carbed setups, hell they dont even run cooling systems on methanol cars, thats how cold they run. I personally think you would be better off ditching the IC and its weight and effect on spool. The weight break off the nose would offset any gains i think
Grr;211521 wrote:
Running straight E98 you really dont need the intercooler. I have watched quite a few cars setup with methanol and ethanol, and on cool days the intake will frost up. This is very common on carbed setups, hell they dont even run cooling systems on methanol cars, thats how cold they run. I personally think you would be better off ditching the IC and its weight and effect on spool. The weight break off the nose would offset any gains i thinkActually I'm filling my block, so the cooling effect will be helpful when I drive around on the street.
I think the IC will help cooling on really hot days at the track and keep the temps down when we run 45+ lbs of boost. -
Filled block alcohol burning back halved cars are NOT street cars Matt. I don't know if you got the memo or not hahahaha.
integra_gsr98;211548 wrote:
Filled block alcohol burning back halved cars are NOT street cars Matt. I don't know if you got the memo or not hahahaha.E98 ethanol...just trying to be "green" and doing my part to save the planet.
It's all in the mind of the beholder.
Ah. That's a very liberal thing of you to do.
I say throw 6 more on there...how many cars you see running around w/ tertiary injectors for when the secondaries run out?
so are these drag cars or show cars?
cannot believe how clean those bad boys are.
Props to ya.Monty
