  4. Project: putting a real motor in a RX-7
79 Posts 24 Posters 3.9k Views
    squawsnatch
    i still cant believe it...........V8 in zacs rx7.......never did i ever see that coming.
    • z31Z Offline
      z31Z Offline
      z31
      I like the look of the Pro Producks Typhoon intake manifolds.:icon_cheers:
        integra_gsr98;213141 wrote:
        Why not reuse your 42? You got it back didn't you?
        eh i just let it go with everything else i sold.......... the turbine was kinda cripy too 🙂
          looks good.. if you have any questions shoot me a pm or have gary call me...
            well best of luck with the swap man!
            • D Offline
              D Offline
              dynotune
              i commend you for the LS swap... I think there is going to be more than one non-GM LS car looming around fargo, FYI!. The FAST intake is the best, although they are spendy (FAST 90mm / 90 mm t-body). Weiand has a newer composite intake as well that is better than the FAST and only $550ish, but I am not sure if it is production, yet. TPIS make a LS6 with a modifed 90 inlet that works just as good as the FAST as well. if you got to TPIS.com they have there dyno comparison. The prof products isn't a bad piece, but they heat soak terribly (really thick alum) they get to the point you can't even put your hand on them (especially forced induction). I'm sure that turbo will spool, but it may be pretty late, not sure. Good luck though, I have seen quite a few of those swaps personally and they are clean and lotsa options for parts later... If you change from the truck intake you will need to change accessory brackets and crank pulley, I BELIEVE. just an warning.
              DynoTune Speed & Performance
              Mobile chassis dyno service
              www.dynotuneusa.com
              (605) 753-1101
                Thanks for just giving me your ###....... I see how it is 😞
                Thanks for the info andy
                  dynotune;213162 wrote:
                  Weiand has a newer composite intake as well that is better than the FAST and only $550ish, .
                  http://videos.streetfire.net/video/SEMA-2007---New-Weiand-LSX-Intake-Manifold_140528.htm
                  good pics >>http://ls1tech.com/forums/showthread.php?t=807431
                  Badass, they did some homework..... but where to get it
                  says in the vid release March 08......seems delayed though from what i read
                    call me anytime big boy :rolleyes:
                    • z31Z Offline
                      z31Z Offline
                      z31
                      dynotune, i didn't see a city-date schedule for this area on your home page. :icon_scratch:
                        trader! you bring me into the rotary world, then bail!
                          because he is smart... :stirpot:
                            haha. that's ok. I'm selling mine too.
                            • 9 Offline
                              9 Offline
                              91psiTSI
                              Zac you need a V8 to keep up with the little 4 banger talon? lol. Good luck dude!
                              • z31Z Offline
                                z31Z Offline
                                z31
                                Z Brown's LS 4.8 tear down.
                                Gary's hard work.:icon_santa:
                                  Cool stuff, will be interesting to see it come together. 🙂
                                  Lag monster? I would have thought that with the relatively big cube motor it should spool that pea shooter pretty well? Faul's gonna be spooling a S480 with a 1.32 a/r T6 with his little 183 cid. There is a pic of his setup in the dictionary under the definition for lag.
                                  :drunken_smilie:
                                    shits gunna blow son!
                                      Was that thing buried in the mud at the junk yard or what?
                                        :drunken_smilie:
                                        lol, you forgot his setup also under the definition for N20....:)
                                        I am used to it...... so no big surprise or reaction i guess :rolleyes:
                                        I dunno, they pulled it the day before it got picked up out of a rolled 2wd....... maybe it rolled into a lake?? lol
                                          C'mon get that thing blasted and painted you two............ I wanna get excited
                                          ............please??
