  4. Torque wrench info
Torque wrench info
11 Posts 6 Posters 411 Views
    I found this today and thought it was kind of interesting.
    The Proper use of a Torque Wrench
    Many times I have heard people complain that these come loose (Control arms are an example). I ask if they torqued to factory specs and I always get the "Yes I did..", then I ask if they adjusted for the preload (frictional drag torque) on the nut. "Huh???" There torque is inevitably lower than factory because they forgot this point.
    Stated torque measurements factor in the frictional force of clean parts, so make certain that everything is clean, and has no burrs. Measuring for Pre-load (frictional drag torque) is fairly easy in theory. The textbook way assumes that you are screwing the nut onto a stationary bolt or thread; we all know this doesn't work, since our stuff is not stationary. Here is the easiest way to do it. Jam the bolt head with a wrench against something so that it won't move. Don't hold it in your hand, since you will have some give there, and may get an inaccurate measurement. Take the nut and screw it on until it stops (hand tight), then take the torque wrench and turn the nut. Start with the lowest setting and work your way up if you are using a micrometer torque, if you are using a beam style, just watch the pointer, the point at which the nut turns is the pre-load (frictional drag torque). You then just add this to the torque you want to go to. i.e. 10ft/lb pre-load (frictional drag torque) + 100ft/lb torque setting = 110ft/lb setting on the torque wrench. There is another pre-load computation for bolts based upon tension/torsion/bolt stretch/ friction/ etc... I really don't want to get into that side, since it really doesn't have a purpose in our application. For those of us with torque wrenches, here is something that I forget to do also. Something to keep in mind when we use them.
    Preloading a torque wrench is an important to the overall accuracy. It must be performed each time the torque wrench is used after periods of non-use or whenever torque direction is changed. There are several reasons for preloading your torque wrench. First, it will set internal components so that when force is applied, torque begins immediately with no internal settling. Second, it distributes lubrication to moving internal parts.
    How to do it:
    1. Set torque wrench between 50 percent and 100 percent of full scale.
    2. Mount torque drive in a stationary fixture (i.e. socket welded to bench, vise).
    3. Exercise the torque wrench three to five times in the direction you will be verifying.
    4. Perform torque measurement.
    Remember to store torque wrenches (click-type) in the low setting. Otherwise calibration will be needed at shorter intervals. You should have your torque wrenches calibrated yearly for accuracy, but it can be costly, so most of us don't do it. I admit that mine are not any longer.
    • z31Z Offline
      z31Z Offline
      z31
      :deal: Buy a SnapOn and dissregaurd all that bullshit. :icon_bigsmurf:
        ummmm... wrong....
        • R Offline
          R Offline
          revolutionz_s13
          snap on will recalibrate their torque wrenchs for free...at least up here they do
          > MisterCMK;207559 wrote:
          > Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
            ^Pretty sure they do down here also. There is probably a reason why every torque wrench at our shop and in our person tools is snap on.
              in order for a torque wrench to be accurate, it needs to be clicked 3-4 times.... i know at catapiler they have a bench with a bunch of welded down nuts, so people can go over there and click their torque wrench a couple times before they use it...
                Perhaps I shall click my torque wrench 6 times tomorrow afternoon.
                Perhaps.
                  pics or BS............
                      Wrong.
                        Nevermind the fact that you guys probably have a snap on truck and lines of credit.
