  3. Motorcycles
  4. Bike Won't Start...HELP!
Scheduled Pinned Locked Moved Motorcycles
23 Posts 9 Posters 5.9k Views
  • D S ohMD Offline
    D S ohMD Offline
    D S ohM
    So I pulled my carbs and cleaned them today. The bike was running like shit the other day. Now Everything is back together and the shit won't start. All it does is turns over and backfires like a motherfucker every now and then...any ideas?
    I wanna go fast!
    • D S ohMD Offline
      D S ohMD Offline
      D S ohM
      Also...any DSM jokes and I <u>WILL</u> punch you.
      I wanna go fast!
        The problem is: YOU cleaned your carbs yourself.
        • GhettoFabulousCRXG Offline
          GhettoFabulousCRX
          What did you put the settings back to? Start with 2 turns out. Or just find out what its supposed to be from a dealer/online manual. You didn't change your needle height did you?
          1993 Nissan 300ZX- Twin Turbo
          1995 civic CX
          2006 Honda CRF50
          1987 Yamaha Ysr-50
          1995 Acura Integra sold
          7 EF civic or crxs sold
          • D S ohMD Offline
            D S ohMD Offline
            D S ohM
            All I did was pull them out, sprayed them down with carb cleaner and brushed them. I didn't adjust anything.
            I wanna go fast!
            • D S ohMD Offline
              D S ohMD Offline
              D S ohM
              Yeah, real helpful. If you don't have real advice then get the fuck out.
              I wanna go fast!
                GhettoFabulousCRX
                Well check it out. I've seen people clean there own carbs and close the air screw all the way not knowing it needs to be turned out to operate. How dirty was the carb?
                1995 civic CX
                2006 Honda CRF50
                1987 Yamaha Ysr-50
                • Racingman24R Offline
                  Racingman24
                  Hate to say it, but spraying them down with carb clean doesn't do all that much. I've had amazing luck with Yamaha's cleaning solution. You mix it with gas, hook it into the gas lines, and and turn it over a few times to get the stuff into the bowls, jets and all the nice little passage ways. let it sit overnight, and drain everything.
                  ANYWAY....now that I'm done babbling. You sure all the vaccum lines are hooked up? And hooked up to where they belong? I know when I cleaned the carbs, I missed a line or two and it didn't run very good. rechecked everything, and fixed the lines, ran like a champ.
                  One other thing....not be be a giant dick...but you did turn the fuel back on, right? I only ask as I've seen people forget it before and wonder why it doesn't start.
                    Racingman24
                    O yea, almost forgot....DSM's are slow. ๐Ÿ˜„
                    • D S ohMD Offline
                      D S ohMD Offline
                      D S ohM
                      Everything is hooked up where it belongs...as far as I know. And yes, I turned the fuel back on.
                      Silence! I keel you!
                      They weren't too bad. A lot better than I thought they would be actually.
                      I wanna go fast!
                      • D S ohMD Offline
                        D S ohMD Offline
                        D S ohM
                        OK...so here is a little update. I went out and the bike started. It wouldn't rev past 1500 and I had to keep my hand on the throttle to keep it running. A few times it revved way up with no power what-so-ever...sounded like a damn v-rod too. After about 5 minutes of this, it started running normal and stayed running without my hand on the throttle. I'm going to let it sit and cool down, then I will try it again and see what happens.
                        I wanna go fast!
                        • D S ohMD Offline
                          D S ohMD Offline
                          D S ohM
                          Yet another update...and another question. Bike is running like a champ. Faster than ever...but still one problem. I still have a nasty hesitation off the start. It picks up after a couple of seconds though. Plugs maybe?
                          I wanna go fast!
                          • GnArKiLlG Offline
                            GnArKiLlG Offline
                            GnArKiLl
                            D S ohM;226822 wrote:
                            Yet another update...and another question. Bike is running like a champ. Faster than ever...but still one problem. I still have a nasty hesitation off the start. It picks up after a couple of seconds though. Plugs maybe? i had this happen to me when i first got the bike. chang the plugs and check the coil packs i replaced them once cuz it was doing the same thing you were talking about.... so hows that bike doin anyways?
                            1976 Chevy K5- lifted beater
                            • D S ohMD Offline
                              D S ohMD Offline
                              D S ohM
                              I'm going to do plugs/coils next weekend. It's doin alright. Helps to have it...DSM is broken.
                              I wanna go fast!
                                OHm... i have an idea for u... dont take anything apart... it usually ends to not starting after... oh and it musta been dsm aids...
                                • D S ohMD Offline
                                  D S ohMD Offline
                                  D S ohM
                                  And now you will be punched next time I see you.
                                  I wanna go fast!
                                  • dubbsyD Offline
                                    dubbsyD Offline
                                    did you check the kill switch?
                                    • D S ohMD Offline
                                      D S ohMD Offline
                                      D S ohM
                                      Ha. If only it had been something simple like that.
                                      I wanna go fast!
                                      • xtreamedrtbkerX Offline
                                        xtreamedrtbker
                                        Itโ€™s a carb problem. Donโ€™t bother replacing the coils, the coils will work or they wonโ€™t. Have you every synchronized the carbs? Any time you pull off a carb bank they should be synced. I would probably say that your idle/pilot circuit is where the problem is going to be in. Where are you idle mixture screws set at? Did you pull the pilot jets out and clean them? Ive cleaned and tuned more carbs then I care to think about so if you have questions just ask away.
                                        Living it up in Phoenix....[SIGPIC][/SIGPIC]
                                        • wishinskyW Offline
                                          wishinskyW Offline
                                          wishinsky
                                          check ur spark plug and make sure its not foiled out.... can ur drive it? and if so does it seem like it loose's power and wants to die when u give it alot of gass? What kinda bike is it?
                                          -Cars i drive
                                          2002 Mustang
                                          1997 Bravada Smart Track
                                          • Toys
                                            05 TTR 125 L/LE
                                            02 YZ 85 with 110cc kit
                                          With your input, this post could be even better ๐Ÿ’—
