  3. Motorcycles
  4. Bike Won't Start...HELP!
Scheduled Pinned Locked Moved Motorcycles
23 Posts 9 Posters 5.9k Views
  • GhettoFabulousCRXG Offline
    GhettoFabulousCRX
    Well check it out. I've seen people clean there own carbs and close the air screw all the way not knowing it needs to be turned out to operate. How dirty was the carb?
    1993 Nissan 300ZX- Twin Turbo
    1995 civic CX
    2006 Honda CRF50
    1987 Yamaha Ysr-50
    1995 Acura Integra sold
    7 EF civic or crxs sold
    • Racingman24R Offline
      Racingman24
      Hate to say it, but spraying them down with carb clean doesn't do all that much. I've had amazing luck with Yamaha's cleaning solution. You mix it with gas, hook it into the gas lines, and and turn it over a few times to get the stuff into the bowls, jets and all the nice little passage ways. let it sit overnight, and drain everything.
      ANYWAY....now that I'm done babbling. You sure all the vaccum lines are hooked up? And hooked up to where they belong? I know when I cleaned the carbs, I missed a line or two and it didn't run very good. rechecked everything, and fixed the lines, ran like a champ.
      One other thing....not be be a giant dick...but you did turn the fuel back on, right? I only ask as I've seen people forget it before and wonder why it doesn't start.
        Racingman24
        O yea, almost forgot....DSM's are slow. πŸ˜„
        • D S ohMD Offline
          D S ohMD Offline
          D S ohM
          Everything is hooked up where it belongs...as far as I know. And yes, I turned the fuel back on.
          Silence! I keel you!
          They weren't too bad. A lot better than I thought they would be actually.
          I wanna go fast!
          • D S ohMD Offline
            D S ohMD Offline
            D S ohM
            OK...so here is a little update. I went out and the bike started. It wouldn't rev past 1500 and I had to keep my hand on the throttle to keep it running. A few times it revved way up with no power what-so-ever...sounded like a damn v-rod too. After about 5 minutes of this, it started running normal and stayed running without my hand on the throttle. I'm going to let it sit and cool down, then I will try it again and see what happens.
            I wanna go fast!
            • D S ohMD Offline
              D S ohMD Offline
              D S ohM
              Yet another update...and another question. Bike is running like a champ. Faster than ever...but still one problem. I still have a nasty hesitation off the start. It picks up after a couple of seconds though. Plugs maybe?
              I wanna go fast!
              • GnArKiLlG Offline
                GnArKiLlG Offline
                GnArKiLl
                D S ohM;226822 wrote:
                Yet another update...and another question. Bike is running like a champ. Faster than ever...but still one problem. I still have a nasty hesitation off the start. It picks up after a couple of seconds though. Plugs maybe? i had this happen to me when i first got the bike. chang the plugs and check the coil packs i replaced them once cuz it was doing the same thing you were talking about.... so hows that bike doin anyways?
                1976 Chevy K5- lifted beater
                • D S ohMD Offline
                  D S ohMD Offline
                  D S ohM
                  I'm going to do plugs/coils next weekend. It's doin alright. Helps to have it...DSM is broken.
                  I wanna go fast!
                    OHm... i have an idea for u... dont take anything apart... it usually ends to not starting after... oh and it musta been dsm aids...
                    • D S ohMD Offline
                      D S ohMD Offline
                      D S ohM
                      And now you will be punched next time I see you.
                      I wanna go fast!
                      • dubbsyD Offline
                        dubbsyD Offline
                        did you check the kill switch?
                        • D S ohMD Offline
                          D S ohMD Offline
                          D S ohM
                          Ha. If only it had been something simple like that.
                          I wanna go fast!
                          • xtreamedrtbkerX Offline
                            xtreamedrtbker
                            It’s a carb problem. Don’t bother replacing the coils, the coils will work or they won’t. Have you every synchronized the carbs? Any time you pull off a carb bank they should be synced. I would probably say that your idle/pilot circuit is where the problem is going to be in. Where are you idle mixture screws set at? Did you pull the pilot jets out and clean them? Ive cleaned and tuned more carbs then I care to think about so if you have questions just ask away.
                            Living it up in Phoenix....[SIGPIC][/SIGPIC]
                            • wishinskyW Offline
                              wishinskyW Offline
                              wishinsky
                              check ur spark plug and make sure its not foiled out.... can ur drive it? and if so does it seem like it loose's power and wants to die when u give it alot of gass? What kinda bike is it?
                              -Cars i drive
                              2002 Mustang
                              1997 Bravada Smart Track
                              • Toys
                                05 TTR 125 L/LE
                                02 YZ 85 with 110cc kit
                              • D S ohMD Offline
                                D S ohMD Offline
                                D S ohM
                                I only cleaned them. I didn't adjust or remove anything from teh carbs themselves. I did check the plugs...and they look awful.
                                I wanna go fast!
                                  Bring it bitch
                                    wishinskyW Offline
                                    wishinsky
                                    ya if they look awful(black) that means it's foiled out...replace them and see what happens or take a wire brush or sand paper and just lightly the end but try not to screw up the gap... because if all u did was cleaned ur carbs and u didnt screw anything up like u said then there should be no problem but yes if ur spark plug is to foiled the bike wont even wont to fire so i would try cleanin or replacein it, just dont get it wet.. and also kick ur bike a couple of time without the spark plug in so it can dry out if its wet on the inside
                                    -Cars i drive
                                    2002 Mustang
                                    • Toys
                                      05 TTR 125 L/LE
                                    With your input, this post could be even better πŸ’—
