  3. Motorcycles
  4. Bike Won't Start...HELP!
Scheduled Pinned Locked Moved Motorcycles
23 Posts 9 Posters 5.9k Views
  • D S ohMD Offline
    D S ohMD Offline
    D S ohM
    I'm going to do plugs/coils next weekend. It's doin alright. Helps to have it...DSM is broken.
    I wanna go fast!
      OHm... i have an idea for u... dont take anything apart... it usually ends to not starting after... oh and it musta been dsm aids...
      • D S ohMD Offline
        D S ohMD Offline
        D S ohM
        And now you will be punched next time I see you.
        I wanna go fast!
        • dubbsyD Offline
          dubbsyD Offline
          did you check the kill switch?
          • D S ohMD Offline
            D S ohMD Offline
            D S ohM
            Ha. If only it had been something simple like that.
            I wanna go fast!
            • xtreamedrtbkerX Offline
              xtreamedrtbker
              It’s a carb problem. Don’t bother replacing the coils, the coils will work or they won’t. Have you every synchronized the carbs? Any time you pull off a carb bank they should be synced. I would probably say that your idle/pilot circuit is where the problem is going to be in. Where are you idle mixture screws set at? Did you pull the pilot jets out and clean them? Ive cleaned and tuned more carbs then I care to think about so if you have questions just ask away.
              Living it up in Phoenix....[SIGPIC][/SIGPIC]
              • wishinskyW Offline
                wishinskyW Offline
                wishinsky
                check ur spark plug and make sure its not foiled out.... can ur drive it? and if so does it seem like it loose's power and wants to die when u give it alot of gass? What kinda bike is it?
                -Cars i drive
                2002 Mustang
                1997 Bravada Smart Track
                • Toys
                  05 TTR 125 L/LE
                  02 YZ 85 with 110cc kit
                • D S ohMD Offline
                  D S ohMD Offline
                  D S ohM
                  I only cleaned them. I didn't adjust or remove anything from teh carbs themselves. I did check the plugs...and they look awful.
                  I wanna go fast!
                    Bring it bitch
                      wishinskyW Offline
                      wishinsky
                      ya if they look awful(black) that means it's foiled out...replace them and see what happens or take a wire brush or sand paper and just lightly the end but try not to screw up the gap... because if all u did was cleaned ur carbs and u didnt screw anything up like u said then there should be no problem but yes if ur spark plug is to foiled the bike wont even wont to fire so i would try cleanin or replacein it, just dont get it wet.. and also kick ur bike a couple of time without the spark plug in so it can dry out if its wet on the inside
                      -Cars i drive
                      2002 Mustang
                      • Toys
                        05 TTR 125 L/LE
