  3. Motorcycles
  4. Bike Won't Start...HELP!
Scheduled Pinned Locked Moved Motorcycles
23 Posts 9 Posters 6.0k Views
  • D S ohMD
    D S ohMD
    D S ohM
    Yet another update...and another question. Bike is running like a champ. Faster than ever...but still one problem. I still have a nasty hesitation off the start. It picks up after a couple of seconds though. Plugs maybe?
    I wanna go fast!
    • GnArKiLlG
      GnArKiLlG
      GnArKiLl
      D S ohM;226822 wrote:
      Yet another update...and another question. Bike is running like a champ. Faster than ever...but still one problem. I still have a nasty hesitation off the start. It picks up after a couple of seconds though. Plugs maybe? i had this happen to me when i first got the bike. chang the plugs and check the coil packs i replaced them once cuz it was doing the same thing you were talking about.... so hows that bike doin anyways?
      1976 Chevy K5- lifted beater
      • D S ohMD
        D S ohMD
        D S ohM
        I'm going to do plugs/coils next weekend. It's doin alright. Helps to have it...DSM is broken.
        I wanna go fast!
        • bubbaB
          bubbaB
          OHm... i have an idea for u... dont take anything apart... it usually ends to not starting after... oh and it musta been dsm aids...
          • D S ohMD
            D S ohMD
            D S ohM
            And now you will be punched next time I see you.
            I wanna go fast!
            • dubbsyD
              dubbsyD
              did you check the kill switch?
              • D S ohMD
                D S ohMD
                D S ohM
                Ha. If only it had been something simple like that.
                I wanna go fast!
                • xtreamedrtbkerX
                  xtreamedrtbkerX
                  xtreamedrtbker
                  It’s a carb problem. Don’t bother replacing the coils, the coils will work or they won’t. Have you every synchronized the carbs? Any time you pull off a carb bank they should be synced. I would probably say that your idle/pilot circuit is where the problem is going to be in. Where are you idle mixture screws set at? Did you pull the pilot jets out and clean them? Ive cleaned and tuned more carbs then I care to think about so if you have questions just ask away.
                  Living it up in Phoenix....[SIGPIC][/SIGPIC]
                  • wishinskyW
                    wishinskyW
                    wishinsky
                    check ur spark plug and make sure its not foiled out.... can ur drive it? and if so does it seem like it loose's power and wants to die when u give it alot of gass? What kinda bike is it?
                    -Cars i drive
                    2002 Mustang
                    1997 Bravada Smart Track
                    • Toys
                      05 TTR 125 L/LE
                      02 YZ 85 with 110cc kit
                    • D S ohMD
                      D S ohMD
                      D S ohM
                      I only cleaned them. I didn't adjust or remove anything from teh carbs themselves. I did check the plugs...and they look awful.
                      I wanna go fast!
                      • bubbaB
                        bubbaB
                        Bring it bitch
                        • wishinskyW
                          wishinskyW
                          wishinsky
                          ya if they look awful(black) that means it's foiled out...replace them and see what happens or take a wire brush or sand paper and just lightly the end but try not to screw up the gap... because if all u did was cleaned ur carbs and u didnt screw anything up like u said then there should be no problem but yes if ur spark plug is to foiled the bike wont even wont to fire so i would try cleanin or replacein it, just dont get it wet.. and also kick ur bike a couple of time without the spark plug in so it can dry out if its wet on the inside
                          -Cars i drive
                          2002 Mustang
                          • Toys
                            05 TTR 125 L/LE
