  4. Time for new parts for the TH-400
29 Posts 12 Posters 1.1k Views
    Any specific reason this happened, or was it pretty much just a weak link?
    In for pushing lol.
      integra_gsr98;230954 wrote:
      I'll help push it in if all else fails Bill. 😜
      ill do the same bill!
        It'll take 10-12 guys anyways to get that thing pushed anywhere. 😛
        • XJHEADX Offline
          XJHEADX Offline
          Getting close, anymore volunteers?????
          In for pushing lol.
          Made a few calls this AM, the second gear sprag is the toughest stock TH-400 sprag they make. They said it would have lived 1,000+ in a light car. About 750 in a heavy one, hmmm maybe I didn't tell them what I had and what HP levels I was going to be at when this was built.... Anyways found a custom part, but takes a new front drum with it $$$$ should be good for 2000 hp.
          Thanks for the offers on pushing it in. Parts should be here Thursday. I am trying to get back into town Late Thursday night and start rebuilding it. Hopefully all goes good and I can finish by Friday night. Gotta learn how to do this stuff sometime...
            im sure we could get more!
            • fallguyF Offline
              fallguyF Offline
              fallguy
              Bill, don't forget Dave has the 4 wheeler to pull your beast in the show....we used it for Probezilla last year. 😛
              1990 Ford Probe GT 2jz RWD
                Ha, I was just thinking the same thing. This will be the first year we've been able to drive both of our cars into and out of P10. It seems only fitting that we pulls Bills car in.
                • XJHEADX Offline
                  XJHEADX Offline
                  Well if your cars will be under their own power and I have issues I'll somehow connect the flex-plate to the driveshaft.... Just don't be in front of the car when I start it....
                  • kylushK Offline
                    kylushK Offline
                    kylush
                    :lol:
                    1998 Z28 Camaro
                    • z31Z Offline
                      z31Z Offline
                      z31
                      Bill, I thought everybody could rebuild/modify GM Turbo 400 transmissions blindfolded :icon_scratch:
                      Do you have any info on the brand of parts used on the original build ?
                      • XJHEADX Offline
                        XJHEADX Offline
                        Well I guess I'll see you Thursday night. I can drink beer while you are putting it together. Nothing really wrong with the parts that were in it. They were just your typical TH-400 rebuild parts for racing applications just not good enough I guess. I talked to a guy with a heavy car like mine. He rolled over 6 sprags before he finally changed out the front drum to fit a 36 element sprag, hasn't had any issues with it. Hopefully this will take care of things. Next the rearend or the motor will go.
                        • z31Z Offline
                          z31Z Offline
                          z31
                          If we are not busy at work I can help you. :icon_bigsmurf:
                          • XJHEADX Offline
                            XJHEADX Offline
                            Just called the office, no parts, thanx UPS
                              UPS FTL! I have always had better luck with USPS Priority Mail. 2-3 day delivery(2 days most, sometimes even overnight), and it's a ton cheaper than UPS. Then again, coming from a vendor sometimes there is nothing you can do.
                              • XJHEADX Offline
                                XJHEADX Offline
                                Found a torn seal in the direct drum.. Was told that would explain the transbrake issues. Also would cause the clutches to fry.
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  Out in less than 1 hour.
                                    so have you found the verdict yet this time around??
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      Doesn't want to come apart, looking for bigger sledgehammer
                                      • 95accord9 Offline
                                        95accord9 Offline
                                        95accord
                                        i have a 20lb sledge at work lol
                                        05 Toyota Corolla- Wifys car
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          Sounds like you have a clutch pack melted together.:icon_scratch:
