  4. Time for new parts for the TH-400
29 Posts 12 Posters 1.1k Views
    It'll take 10-12 guys anyways to get that thing pushed anywhere. 😛
    • XJHEADX Offline
      XJHEADX Offline
      Getting close, anymore volunteers?????
      PSiedTSi;230955 wrote:
      Any specific reason this happened, or was it pretty much just a weak link?
      In for pushing lol.
      Made a few calls this AM, the second gear sprag is the toughest stock TH-400 sprag they make. They said it would have lived 1,000+ in a light car. About 750 in a heavy one, hmmm maybe I didn't tell them what I had and what HP levels I was going to be at when this was built.... Anyways found a custom part, but takes a new front drum with it $$$$ should be good for 2000 hp.
      Thanks for the offers on pushing it in. Parts should be here Thursday. I am trying to get back into town Late Thursday night and start rebuilding it. Hopefully all goes good and I can finish by Friday night. Gotta learn how to do this stuff sometime...
        im sure we could get more!
        • fallguyF Offline
          fallguyF Offline
          fallguy
          Bill, don't forget Dave has the 4 wheeler to pull your beast in the show....we used it for Probezilla last year. 😛
          1990 Ford Probe GT 2jz RWD
            Ha, I was just thinking the same thing. This will be the first year we've been able to drive both of our cars into and out of P10. It seems only fitting that we pulls Bills car in.
            • XJHEADX Offline
              XJHEADX Offline
              Well if your cars will be under their own power and I have issues I'll somehow connect the flex-plate to the driveshaft.... Just don't be in front of the car when I start it....
              • kylushK Offline
                kylushK Offline
                kylush
                :lol:
                1998 Z28 Camaro
                • z31Z Offline
                  z31Z Offline
                  z31
                  Bill, I thought everybody could rebuild/modify GM Turbo 400 transmissions blindfolded :icon_scratch:
                  Do you have any info on the brand of parts used on the original build ?
                  • XJHEADX Offline
                    XJHEADX Offline
                    Well I guess I'll see you Thursday night. I can drink beer while you are putting it together. Nothing really wrong with the parts that were in it. They were just your typical TH-400 rebuild parts for racing applications just not good enough I guess. I talked to a guy with a heavy car like mine. He rolled over 6 sprags before he finally changed out the front drum to fit a 36 element sprag, hasn't had any issues with it. Hopefully this will take care of things. Next the rearend or the motor will go.
                    • z31Z Offline
                      z31Z Offline
                      z31
                      If we are not busy at work I can help you. :icon_bigsmurf:
                      • XJHEADX Offline
                        XJHEADX Offline
                        Just called the office, no parts, thanx UPS
                          UPS FTL! I have always had better luck with USPS Priority Mail. 2-3 day delivery(2 days most, sometimes even overnight), and it's a ton cheaper than UPS. Then again, coming from a vendor sometimes there is nothing you can do.
                          • XJHEADX Offline
                            XJHEADX Offline
                            Found a torn seal in the direct drum.. Was told that would explain the transbrake issues. Also would cause the clutches to fry.
                            • XJHEADX Offline
                              XJHEADX Offline
                              Out in less than 1 hour.
                                so have you found the verdict yet this time around??
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  Doesn't want to come apart, looking for bigger sledgehammer
                                  • 95accord9 Offline
                                    95accord9 Offline
                                    95accord
                                    i have a 20lb sledge at work lol
                                    05 Toyota Corolla- Wifys car
                                    • z31Z Offline
                                      z31Z Offline
                                      z31
                                      Sounds like you have a clutch pack melted together.:icon_scratch:
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        Don't need it, I found my 18 lb'r. Got it apart again, only thing that is hurt is the reverse band clutch. For some reason it isn't applying hard enough.
                                        I guess I didn't mention but I still had T-brake issues after re-build. I took it out Monday night with 20+ lbs. for 20 minutes. 1-2-3 are all good. Beat on the t-brake and some fast backing up, finally got both to fail, no reverse or transbrake.
                                          ha, well atleast you know what is going on now
