  4. Stang with remote twins in trunk
14 Posts 9 Posters 1.2k Views
  • JN210J Offline
    JN210J Offline
    JN210
    Now thats cool.
    *1989 Nissan 300ZX Z31 *
    > DelSlow;262050 wrote:
    > I like the new JN210
    • StangerBanger96S Offline
      StangerBanger96
      Can't watch at work but there was custom build on stangnet several years ago where the guy turned the side scoops on the rear quarters into functional intakes for his remote twins...is the mustang in this video green?
        This is Murillo (sp?)'s star car 3. It is a very bad ass build that is for sure
        • RaiderR Offline
          RaiderR Offline
          Raider
          wasnt #2 remote twins also?
          POWERD BY
          • BassplayerB Offline
            BassplayerB Offline
            Bassplayer
            Wow thats pimp, def something different.
            1995 GMC Sierra
              that is one BA Fox!
                says star car II right in the video....
                  Thats pretty badass. Looks like more work to put the turbos in the back, instead of the front though.
                    It really is alot easier. Most of the classes these guys run in require the exhaust to exit past the firewall anyway, and now getting a 2.5" or 3" pipe to the back is way easier than getting a 5" or a couple 4-5" DPs in there. Also they all run huge W2A intercoolers in the cockpit, and with this the air flows rear>front in a nice straight line instead of fitting 2 pipes through the firewall. Also when this was built the total piping was alot less than a regular front mount system, therefore more efficient. Not to mention the huge amount of room gained in the engine compartment and the added weight in the rear of the car to balance it out.
                    • RaiderR Offline
                      RaiderR Offline
                      Raider
                      I know of a guy who is changing his single turbo setup on his F150 to twins mounted in the box...going to be similar to same setup as this mustang
                      POWERD BY
                        meh...
                        A remote system no matter how well designed cannot be as efficient as a non remote system with the same amount of designing....
                          Still thats a lot of piping running back there, 2 IC pipes, 2 exhaust pipes. Running an oil pump and oil lines, then oil return lines. I'm guessing they needed some brackets or something to hold the turbos in place. Idk, either way it works good on that car.
