Stang with remote twins in trunk
kind of a different setup to have twins in the trunk with the intakes off the side quarters...but running 7's I guess it works
http://videos.streetfire.net/video/Mike-Murillo-Motorsports_140788.htm
Can't watch at work but there was custom build on stangnet several years ago where the guy turned the side scoops on the rear quarters into functional intakes for his remote twins...is the mustang in this video green?
Wow thats pimp, def something different.
Grr;233054 wrote:
This is Murillo (sp?)'s star car 3. It is a very bad ass build that is for suresays star car II right in the video....
It really is alot easier. Most of the classes these guys run in require the exhaust to exit past the firewall anyway, and now getting a 2.5" or 3" pipe to the back is way easier than getting a 5" or a couple 4-5" DPs in there. Also they all run huge W2A intercoolers in the cockpit, and with this the air flows rear>front in a nice straight line instead of fitting 2 pipes through the firewall. Also when this was built the total piping was alot less than a regular front mount system, therefore more efficient. Not to mention the huge amount of room gained in the engine compartment and the added weight in the rear of the car to balance it out.
Still thats a lot of piping running back there, 2 IC pipes, 2 exhaust pipes. Running an oil pump and oil lines, then oil return lines. I'm guessing they needed some brackets or something to hold the turbos in place. Idk, either way it works good on that car.
