  4. msd 6a ignition problems
11 Posts 7 Posters 945 Views
    check your big ole fuses under da hood. what car
    • i_like_eggsI Offline
      i_like_eggs
      its my 94 accord,
      [SIGPIC][/SIGPIC] ever had a heavenly frank?
        Just take the box out and run OEM stuff. Unless you have some secret need for having it.
          OEM Ignition FTW. unless you are running 500+ whp, you will be fine with stock ignition, way less hassle to deal with.
            Look for the 80 amp fuse in your fuse box. Its a black one with a clear top. I'll lay odds you popped that one. It takes a 10mm wrench socket to remove it. Ask me how I know. Let me know if this helps.
              The cars running fine now, eggs and goodnbuzzd check all the fuses and they were all good. They pulled to ecu fuse and put it back and it started, it coughed a bit but it started. The jolt must have made the the ecu hiccup.
                i_like_eggs
                thanks for all the ideas, ichiban got to the site before me to let all know it came back to life...lol:drunken_smilie:
                  ^ listen to him...
                    i_like_eggs
                    the oem is dead, or at least the coil is...
                      A new coil is a lot cheaper than a full MSD set up that does nothing for you, and a lot more reliable.
