  4. just curious about hp...
64 Posts 18 Posters 8.9k Views
  • blackcherryTSiB Offline
    blackcherryTSi
    SPANISH-RICE;243818 wrote:
    make sure to paint the block so it looks nice, and then fill out the online application for joinging the PVC squad
    idk if this is a noob question but what is the PVC squad?
    1995 Honda Civic
      blackcherryTSi
      no_slow_clap;243810 wrote:
      a 16g will be better, but with small turbos like that your going to max them out super fast.
      IMO....50 trim, and call it a day.
      how much does one of those run for price and hp?
      1995 Honda Civic
        50trim would put down more power then you need. You can get a new one for like $600.
        • ihaveaidsI Offline
          ihaveaidsI Offline
          ihaveaids
          Should be able to find a good used on on honda tech for cheaper than that. I know I sold my old one for $400...
            A eagle vitara build will hold more power than a t3 50 trim will put out.
            • G Offline
              G Offline
              GoldyHatchPSI
              Nothing less than a 50 trim. If you think about it you're gonna want more power after you drive it on that setup then you'll just have to tune again if you get a bigger turbo. Just do it right the first time or you'll be wasting your money. Go big or go home. That's just me tho.
              • capitljC Offline
                capitljC Offline
                capitlj
                zbrown;243817 wrote:
                no..... rotaries do
                No..... everything does.
                > Mitch Hedberg wrote:
                2004 Impala LS 3.8
                  Yeah, like everyone else said, your turbo is definately your limitation. If you get a bigger turbo, pm me and i might take the 14b.
                  • gsrEKG Offline
                    gsrEKG Offline
                    gsrEK
                    true. i maxed my 50 trim out at 270 whp on a mustang dyno at 18 psi. i wish i woulda got a bigger turbo also.
                    my setup is a tuner toys-vitara and i ran a 12.3 at 114 on a pretty cheap build. i just sold my 50 trim on sunday lol for 350 bucks and that would have been perfect for ya. next year gonna go for 400hp. any questions about it just ask. also my setup is for sale pm me if interested
                    2009 Yamaha Zuma 125, gas HOG
                    2008 Honda Fit daily
                    A s2k
                    1991 Honda civic DX Mint SOLD
                    1988 Mitsubishi Mighty max
                    > BlackEJ8;233529 wrote:
                      the 14b will make plenty of power for starting out. alot of ppl get to big of turbo's and end up hating it or it acually runs slower as they need to rev to 5k+ just to get into boost and have a little fun.
                      like brandons car is fast and all but it is borring as hell on the street, thing just doesn't spool up the way a street car should imo.
                      just stick with the 14b, and you can later upgrade to a 16g or a 20g, and not have to change much on your set up, then changing to a completely different turbo.
                        and what has this got to do with a noob building his first turbo build, and not needing 400hp+ and kill himself, or hit a tree:icon_scratch:
                        plus travis' 50 trim is not a "normal" 50 trim. it is alot smaller.
                          I was wondering aswell if they were talking about a t3 50 trim comp. or a t4 E-cover 50 trim comp..... because that is a huge difference
                            it just seems easier to have a turbo thats capabale of coming closer to his goals right away. that way he doesnt need to switch turbo/manifolds/intercooler piping/oil lines.
                            itd be alot easier to tell him what turbo he should get if we knew if it was a street car or a track car and what he wants to rev to and what power he actually wants.
                            for all we know he wants the power that the 14b will put out i just dont think thats the case. with that motor 300 streetable is not difficult. even with the uber low compression.
                            so instead of telling him to get bigger turbos maybe we should be asking what he wants from this build lol
                                trim doesnt really mean anything other than a ratio of inducer diameter to exducer diameter. you can have a 76 trim that only flows 100hp. i dont like when people assume trim size is turbo size.
                                  no shit shurlock.....obviously i understand what trim is, and wasn't using trim to demonstrate turbo size
                                  but that is the common name people use to describe some variants of turbos......
                                  how else would describe a 50 trim t3 comp., or a 50 trim t04e comp. to someone???
                                  let me guess..... i um have a 42.5mm ind./60mm exd. t3 comp...... or a 54mm ind./76mm exd. to4e comp.
                                  get real...
                                  The comp. on my gt4202 was a 53 trim..... but is that the common name for it??.... fuck no
                                  different lines of turbos are obviously named/labeled differently
                                  I am glad you threw your 2 cents of Turbo 101 in there to show your mad turbo skillz....
                                  • darkelvisD Offline
                                    darkelvisD Offline
                                    darkelvis
                                    just use the .ar specs combined with the trim....it'll actually tell you what the turbo is. 🙂
                                      get real...
                                      Woaaa dont get all defensive the only reason why you are involved at all with anything i said was becuase i fucking agreed with you. I was saying that for other people like travis who seemed confused by the idea of someone using a 50 trim and making more power than 270hp.
                                      But im glad that you also know what i know, and that you feel the need to throw around dimensions and basic math i already knew about your useless fucking turbo. Any one can use google and tell you your in./ex. Diameters, congrats
                                      stop trying to sound so smart by telling people the small about about basic shit that you know
                                      • gsrEKG Offline
                                        gsrEKG Offline
                                        gsrEK
                                        um yea. im not too confused anymore.....
                                        A s2k
