  4. just curious about hp...
64 Posts 18 Posters 8.9k Views
    KA-T_240;243833 wrote:
    50trim would put down more power then you need. You can get a new one for like $600.
    A eagle vitara build will hold more power than a t3 50 trim will put out.
    • G Offline
      G Offline
      GoldyHatchPSI
      Nothing less than a 50 trim. If you think about it you're gonna want more power after you drive it on that setup then you'll just have to tune again if you get a bigger turbo. Just do it right the first time or you'll be wasting your money. Go big or go home. That's just me tho.
      • capitljC Offline
        capitljC Offline
        capitlj
        zbrown;243817 wrote:
        no..... rotaries do
        No..... everything does.
        > Mitch Hedberg wrote:
        2004 Impala LS 3.8
          Yeah, like everyone else said, your turbo is definately your limitation. If you get a bigger turbo, pm me and i might take the 14b.
          • gsrEKG Offline
            gsrEKG Offline
            gsrEK
            true. i maxed my 50 trim out at 270 whp on a mustang dyno at 18 psi. i wish i woulda got a bigger turbo also.
            my setup is a tuner toys-vitara and i ran a 12.3 at 114 on a pretty cheap build. i just sold my 50 trim on sunday lol for 350 bucks and that would have been perfect for ya. next year gonna go for 400hp. any questions about it just ask. also my setup is for sale pm me if interested
            2009 Yamaha Zuma 125, gas HOG
            2008 Honda Fit daily
            A s2k
            1991 Honda civic DX Mint SOLD
            1988 Mitsubishi Mighty max
            > BlackEJ8;233529 wrote:
              the 14b will make plenty of power for starting out. alot of ppl get to big of turbo's and end up hating it or it acually runs slower as they need to rev to 5k+ just to get into boost and have a little fun.
              like brandons car is fast and all but it is borring as hell on the street, thing just doesn't spool up the way a street car should imo.
              just stick with the 14b, and you can later upgrade to a 16g or a 20g, and not have to change much on your set up, then changing to a completely different turbo.
                and what has this got to do with a noob building his first turbo build, and not needing 400hp+ and kill himself, or hit a tree:icon_scratch:
                plus travis' 50 trim is not a "normal" 50 trim. it is alot smaller.
                  I was wondering aswell if they were talking about a t3 50 trim comp. or a t4 E-cover 50 trim comp..... because that is a huge difference
                    it just seems easier to have a turbo thats capabale of coming closer to his goals right away. that way he doesnt need to switch turbo/manifolds/intercooler piping/oil lines.
                    itd be alot easier to tell him what turbo he should get if we knew if it was a street car or a track car and what he wants to rev to and what power he actually wants.
                    for all we know he wants the power that the 14b will put out i just dont think thats the case. with that motor 300 streetable is not difficult. even with the uber low compression.
                    so instead of telling him to get bigger turbos maybe we should be asking what he wants from this build lol
                        trim doesnt really mean anything other than a ratio of inducer diameter to exducer diameter. you can have a 76 trim that only flows 100hp. i dont like when people assume trim size is turbo size.
                          no shit shurlock.....obviously i understand what trim is, and wasn't using trim to demonstrate turbo size
                          but that is the common name people use to describe some variants of turbos......
                          how else would describe a 50 trim t3 comp., or a 50 trim t04e comp. to someone???
                          let me guess..... i um have a 42.5mm ind./60mm exd. t3 comp...... or a 54mm ind./76mm exd. to4e comp.
                          get real...
                          The comp. on my gt4202 was a 53 trim..... but is that the common name for it??.... fuck no
                          different lines of turbos are obviously named/labeled differently
                          I am glad you threw your 2 cents of Turbo 101 in there to show your mad turbo skillz....
                          • darkelvisD Offline
                            darkelvisD Offline
                            darkelvis
                            just use the .ar specs combined with the trim....it'll actually tell you what the turbo is. 🙂
                              get real...
                              Woaaa dont get all defensive the only reason why you are involved at all with anything i said was becuase i fucking agreed with you. I was saying that for other people like travis who seemed confused by the idea of someone using a 50 trim and making more power than 270hp.
                              But im glad that you also know what i know, and that you feel the need to throw around dimensions and basic math i already knew about your useless fucking turbo. Any one can use google and tell you your in./ex. Diameters, congrats
                              stop trying to sound so smart by telling people the small about about basic shit that you know
                              • gsrEKG Offline
                                gsrEKG Offline
                                gsrEK
                                um yea. im not too confused anymore.....
                                A s2k
                                    Who said I was talking about a "t3" 50trim. When the most people talk about a 50trim It is a t3/t4 50trim.
                                      Wow...honestly, some people cant help but be deuschebags....
                                      • blackcherryTSiB Offline
                                        blackcherryTSi
                                        im going for a street car thats got some fast spool up and some alrite power to have at stop lights and race nights and such.... to too much of a track car. maybe see it once or twice just for numbers. the only reason why i totally built the engine is because just in case i want that 300+ hp then i can change just the turbo and stuff.... dont want a car like 1990tsi's that is pretty much useless in town. also want to be able to hook up decent in 1 and 2nd
                                        1995 Honda Civic
                                          blackcherryTSi
                                          also my budgets starting to wear thin so i want to take advangtage of the lower priced decent power turbos like the 14b and 16g but im still undecided as well as with pump gas or e85
                                          1995 Honda Civic
