  4. just curious about hp...
64 Posts 18 Posters 8.9k Views
      trim doesnt really mean anything other than a ratio of inducer diameter to exducer diameter. you can have a 76 trim that only flows 100hp. i dont like when people assume trim size is turbo size.
        no shit shurlock.....obviously i understand what trim is, and wasn't using trim to demonstrate turbo size
        but that is the common name people use to describe some variants of turbos......
        how else would describe a 50 trim t3 comp., or a 50 trim t04e comp. to someone???
        let me guess..... i um have a 42.5mm ind./60mm exd. t3 comp...... or a 54mm ind./76mm exd. to4e comp.
        get real...
        The comp. on my gt4202 was a 53 trim..... but is that the common name for it??.... fuck no
        different lines of turbos are obviously named/labeled differently
        I am glad you threw your 2 cents of Turbo 101 in there to show your mad turbo skillz....
        • darkelvisD Offline
          darkelvisD Offline
          darkelvis
          just use the .ar specs combined with the trim....it'll actually tell you what the turbo is. 🙂
            get real...
            Woaaa dont get all defensive the only reason why you are involved at all with anything i said was becuase i fucking agreed with you. I was saying that for other people like travis who seemed confused by the idea of someone using a 50 trim and making more power than 270hp.
            But im glad that you also know what i know, and that you feel the need to throw around dimensions and basic math i already knew about your useless fucking turbo. Any one can use google and tell you your in./ex. Diameters, congrats
            stop trying to sound so smart by telling people the small about about basic shit that you know
            • gsrEKG Offline
              gsrEKG Offline
              gsrEK
              um yea. im not too confused anymore.....
              2009 Yamaha Zuma 125, gas HOG
              2008 Honda Fit daily
              A s2k
              1991 Honda civic DX Mint SOLD
              1988 Mitsubishi Mighty max
              > BlackEJ8;233529 wrote:
                  Joel;243838 wrote:
                  A eagle vitara build will hold more power than a t3 50 trim will put out.
                  Who said I was talking about a "t3" 50trim. When the most people talk about a 50trim It is a t3/t4 50trim.
                    Wow...honestly, some people cant help but be deuschebags....
                    • blackcherryTSiB Offline
                      blackcherryTSi
                      SPANISH-RICE;243886 wrote:
                      so instead of telling him to get bigger turbos maybe we should be asking what he wants from this build lol
                      im going for a street car thats got some fast spool up and some alrite power to have at stop lights and race nights and such.... to too much of a track car. maybe see it once or twice just for numbers. the only reason why i totally built the engine is because just in case i want that 300+ hp then i can change just the turbo and stuff.... dont want a car like 1990tsi's that is pretty much useless in town. also want to be able to hook up decent in 1 and 2nd
                      1995 Honda Civic
                        blackcherryTSi
                        also my budgets starting to wear thin so i want to take advangtage of the lower priced decent power turbos like the 14b and 16g but im still undecided as well as with pump gas or e85
                        1995 Honda Civic
                          then why do you want a turbo fwd car? I believe you are after something like Drifterextremes setup. In which case there is NO reason for a built motor, especially if you are on a tight budget... Seems like you have no problem dishing out 250-350 for rods but you cant spend more than 50 bucks for a turbo?
                          • slow90gsxS Offline
                            slow90gsxS Offline
                            slow90gsx
                            Ive got a buddy that has a 20g for sale no shafty play.
                              blackcherryTSi
                              because i eventually want that higher hp but right now i cant. dont u think that it makes more sense to spend the money to build the inside first? i do....
                              1995 Honda Civic
                                blackcherryTSi
                                how much?
                                1995 Honda Civic
                                • gsrEKG Offline
                                  gsrEKG Offline
                                  gsrEK
                                  i had just a bit over 300 hp and my didnt hook on the street lol if you buy some small meathooks you will be fine. also what kind of clutch are you gonna use?
                                  A s2k
                                    blackcherryTSi
                                    i believe it has a act stage 1 in it. i havent pulled that motor to c yet. may use that if still good condition..
                                    1995 Honda Civic
                                      Look into the 20g that would be a fun turbo for the street. But i think those are still mitsu flanged so you would need a new manifold if youd wanna run something different in the future.
                                      And in that case i think you have a perfect motor for what you want. A cost effective build that will handle 450hp if tuned correctly. Prolly gonna wanna get a little beefier clutch tho.
                                        slow90gsxS Offline
                                        slow90gsx
                                        Make offer.
                                          blackcherryTSi
                                          slow90gsx;243974 wrote:
                                          Make offer.
                                          pm'd
                                          1995 Honda Civic
