  4. just curious about hp...
64 Posts 18 Posters 8.9k Views
  • blackcherryTSiB Offline
    blackcherryTSi
    also my budgets starting to wear thin so i want to take advangtage of the lower priced decent power turbos like the 14b and 16g but im still undecided as well as with pump gas or e85
    1995 Honda Civic
      blackcherryTSi;243955 wrote:
      im going for a street car thats got some fast spool up and some alrite power to have at stop lights and race nights and such.... to too much of a track car. maybe see it once or twice just for numbers. the only reason why i totally built the engine is because just in case i want that 300+ hp then i can change just the turbo and stuff.... dont want a car like 1990tsi's that is pretty much useless in town. also want to be able to hook up decent in 1 and 2nd
      then why do you want a turbo fwd car? I believe you are after something like Drifterextremes setup. In which case there is NO reason for a built motor, especially if you are on a tight budget... Seems like you have no problem dishing out 250-350 for rods but you cant spend more than 50 bucks for a turbo?
      • slow90gsxS Offline
        slow90gsxS Offline
        slow90gsx
        Ive got a buddy that has a 20g for sale no shafty play.
          blackcherryTSi
          because i eventually want that higher hp but right now i cant. dont u think that it makes more sense to spend the money to build the inside first? i do....
          1995 Honda Civic
            blackcherryTSi
            how much?
            1995 Honda Civic
            • gsrEKG Offline
              gsrEKG Offline
              gsrEK
              i had just a bit over 300 hp and my didnt hook on the street lol if you buy some small meathooks you will be fine. also what kind of clutch are you gonna use?
              2009 Yamaha Zuma 125, gas HOG
              2008 Honda Fit daily
              A s2k
              1991 Honda civic DX Mint SOLD
              1988 Mitsubishi Mighty max
                blackcherryTSi
                i believe it has a act stage 1 in it. i havent pulled that motor to c yet. may use that if still good condition..
                1995 Honda Civic
                  Look into the 20g that would be a fun turbo for the street. But i think those are still mitsu flanged so you would need a new manifold if youd wanna run something different in the future.
                  And in that case i think you have a perfect motor for what you want. A cost effective build that will handle 450hp if tuned correctly. Prolly gonna wanna get a little beefier clutch tho.
                    slow90gsxS Offline
                    slow90gsx
                    Make offer.
                      blackcherryTSi
                      slow90gsx;243974 wrote:
                      Make offer.
                      pm'd
                      1995 Honda Civic
                        blackcherryTSi
                        whats kinda hp am i looking at with the 20g? and still wondering what the PVC squad is...
                        1995 Honda Civic
                          joel;243957 wrote:
                          then why do you want a turbo fwd car? I believe you are after something like drifterextremes setup. In which case there is no reason for a built motor, especially if you are on a tight budget... Seems like you have no problem dishing out 250-350 for rods but you cant spend more than 50 bucks for a turbo?
                          whats wrong with a turbo fwd car for what he wants? Traction problems? Almost any other application is just going to run into diff problems and costly clutch swaps with that power to get even close to what hes looking for.
                          He spent money where money should be spent, on the motor. Those rods can be had for 220 dollars. More than likely itll handle power alot better over time then matts 4 door . So he spent an extra 400 dollars on his rebuild for some extra insurance, sounds like a good idea to me.
                          And i think if his power goals are rreally as low as he says than the 14b or 16g turbo would be perfect for him, no reason to knock tried and true 200-300 horsepower turbos even if they arent super stupid expensive.
                            blackcherrytsi;243979 wrote:
                            whats kinda hp am i looking at with the 20g? And still wondering what the pvc squad is...
                            supposedly a large 20g is supposed to be good for 400+ might be a tad bit laggy for what your looking for, a 16g would be an awesome budget turbo. But i think the 20g is an awesome turbo
                              blackcherryTSi
                              20g for 350... may do it... undecided.... also had a question.. anybody have a jdm dash peice where the cup holders are? kinda vauge but it turns that into just a pocket
                              1995 Honda Civic
                                slow90gsxS Offline
                                slow90gsx
                                https://secure.buschurracing.com/catalog/product_info.php?cPath=22_38&products_id=434&osCsid=93cf107efb8002a8df95aecaf5226c5c
                                We went to buschur and bought the car from a guy that worked there this is the one^^^
                                  http://passwordjdm.com/EG-92-95-Civic-HOP-Optional-Center-Console-P2359C138.aspx
                                    Please elaborate???..... all knowing one
                                    SPANISH-RICE;243900 wrote:
                                    Woaaa dont get all defensive the only reason why you are involved at all with anything i said was becuase i fucking agreed with you. I was saying that for other people like travis who seemed confused by the idea of someone using a 50 trim and making more power than 270hp.
                                    But im glad that you also know what i know, and that you feel the need to throw around dimensions and basic math i already knew about your useless fucking turbo. Any one can use google and tell you your in./ex. Diameters, congrats
                                    stop trying to sound so smart by telling people the small about about basic shit that you know
                                    You were calling me out, insinuating I was using trim to differentiate the size of turbos...... as bigger or smaller
                                    I only clearly pointed out that different turbos use different characteristics to name them........... and that in this case it was trim that was used
                                    Obviously I looked up the wheel specs of both to illustrate my point....
                                    Since you are so well endowed with the understanding of turbo dynamics will you please help me size the optimum turbo for my setup???........ please master
                                    • 9 Offline
                                      9 Offline
                                      91psiTSI
                                      200hp on 10 psi
                                      • speed_ricer69S Offline
                                        speed_ricer69
                                        hey talk to lil mikey
                                        The Hanson's were the first to invent v-tec. MMM BOOP
                                          the 20g will not be good for his setup right now as i beleave it has a tdo6 compressor wheel and housing? correct me if i'm wrong zac. 1 full size up from the 14b which uses the tdo5 housing, that with the 1 step up turbine wheel and a 10cm turbine housing vs the normal 6 or 7cm turbine housing would slow spool-up, conciderabley.
                                          again with a built bottom end he is capable of running higher boost to compensate for the low compression.
                                          so i don't see how this is a bad set up. he has room to upgrade and it will be plenty fun at the 200-240 whp range with a nice torque curve.
