  4. just curious about hp...
64 Posts 18 Posters 8.9k Views
    the 14b will make plenty of power for starting out. alot of ppl get to big of turbo's and end up hating it or it acually runs slower as they need to rev to 5k+ just to get into boost and have a little fun.
    like brandons car is fast and all but it is borring as hell on the street, thing just doesn't spool up the way a street car should imo.
    just stick with the 14b, and you can later upgrade to a 16g or a 20g, and not have to change much on your set up, then changing to a completely different turbo.
      Joel;243838 wrote:
      A eagle vitara build will hold more power than a t3 50 trim will put out.
      and what has this got to do with a noob building his first turbo build, and not needing 400hp+ and kill himself, or hit a tree:icon_scratch:
      plus travis' 50 trim is not a "normal" 50 trim. it is alot smaller.
        I was wondering aswell if they were talking about a t3 50 trim comp. or a t4 E-cover 50 trim comp..... because that is a huge difference
          it just seems easier to have a turbo thats capabale of coming closer to his goals right away. that way he doesnt need to switch turbo/manifolds/intercooler piping/oil lines.
          itd be alot easier to tell him what turbo he should get if we knew if it was a street car or a track car and what he wants to rev to and what power he actually wants.
          for all we know he wants the power that the 14b will put out i just dont think thats the case. with that motor 300 streetable is not difficult. even with the uber low compression.
          so instead of telling him to get bigger turbos maybe we should be asking what he wants from this build lol
              trim doesnt really mean anything other than a ratio of inducer diameter to exducer diameter. you can have a 76 trim that only flows 100hp. i dont like when people assume trim size is turbo size.
                no shit shurlock.....obviously i understand what trim is, and wasn't using trim to demonstrate turbo size
                but that is the common name people use to describe some variants of turbos......
                how else would describe a 50 trim t3 comp., or a 50 trim t04e comp. to someone???
                let me guess..... i um have a 42.5mm ind./60mm exd. t3 comp...... or a 54mm ind./76mm exd. to4e comp.
                get real...
                The comp. on my gt4202 was a 53 trim..... but is that the common name for it??.... fuck no
                different lines of turbos are obviously named/labeled differently
                I am glad you threw your 2 cents of Turbo 101 in there to show your mad turbo skillz....
                • darkelvisD Offline
                  darkelvisD Offline
                  darkelvis
                  just use the .ar specs combined with the trim....it'll actually tell you what the turbo is. 🙂
                    get real...
                    Woaaa dont get all defensive the only reason why you are involved at all with anything i said was becuase i fucking agreed with you. I was saying that for other people like travis who seemed confused by the idea of someone using a 50 trim and making more power than 270hp.
                    But im glad that you also know what i know, and that you feel the need to throw around dimensions and basic math i already knew about your useless fucking turbo. Any one can use google and tell you your in./ex. Diameters, congrats
                    stop trying to sound so smart by telling people the small about about basic shit that you know
                    • gsrEKG Offline
                      gsrEKG Offline
                      gsrEK
                      um yea. im not too confused anymore.....
                      2009 Yamaha Zuma 125, gas HOG
                      2008 Honda Fit daily
                      A s2k
                      1991 Honda civic DX Mint SOLD
                      1988 Mitsubishi Mighty max
                      > BlackEJ8;233529 wrote:
                          Who said I was talking about a "t3" 50trim. When the most people talk about a 50trim It is a t3/t4 50trim.
                            Wow...honestly, some people cant help but be deuschebags....
                            • blackcherryTSiB Offline
                              blackcherryTSi
                              im going for a street car thats got some fast spool up and some alrite power to have at stop lights and race nights and such.... to too much of a track car. maybe see it once or twice just for numbers. the only reason why i totally built the engine is because just in case i want that 300+ hp then i can change just the turbo and stuff.... dont want a car like 1990tsi's that is pretty much useless in town. also want to be able to hook up decent in 1 and 2nd
                              1995 Honda Civic
                                blackcherryTSi
                                also my budgets starting to wear thin so i want to take advangtage of the lower priced decent power turbos like the 14b and 16g but im still undecided as well as with pump gas or e85
                                1995 Honda Civic
                                  then why do you want a turbo fwd car? I believe you are after something like Drifterextremes setup. In which case there is NO reason for a built motor, especially if you are on a tight budget... Seems like you have no problem dishing out 250-350 for rods but you cant spend more than 50 bucks for a turbo?
                                  • slow90gsxS Offline
                                    slow90gsxS Offline
                                    slow90gsx
                                    Ive got a buddy that has a 20g for sale no shafty play.
                                      blackcherryTSi
                                      because i eventually want that higher hp but right now i cant. dont u think that it makes more sense to spend the money to build the inside first? i do....
                                      1995 Honda Civic
                                        blackcherryTSi
                                        how much?
                                        1995 Honda Civic
                                        • gsrEKG Offline
                                          gsrEKG Offline
                                          gsrEK
                                          i had just a bit over 300 hp and my didnt hook on the street lol if you buy some small meathooks you will be fine. also what kind of clutch are you gonna use?
                                          A s2k
