Pre-Season
Purchased:
Rims
6 Bolt Motor
6 Bolt Flywheel
Rebuilt Transmission
Boost Gauge
Oil Pres Gauge
Water Temp Gauge
Full Replacement Pillar
Sparco Lowering Springs
Balance Shaft Removal KitHopefully soon:
Reverse Indiglo Gauges
FMIC
Type S or RS BOV
Big Turbo
InjectorsPossible:
2G Pistons
Different rice pipe
New Bearings
LSDStupid things:
Fix Downpipe
Fix interior plastic panel creeks
Passenger Side Door Hinge Aligned correctly ( i fucked it up making lambo door hinges lol)
Get my heatcore flushed (or whatever wes told me to do to get my heat working right again) -
YellowEvo wrote:
when you gonna have that new part of the shop goin??Soon very soon. It was supposed to be jan 1 but the current resident was unable to move out due to having back surgery. According to them they have started the move so we should have it available i would assume w/in 2 weeks.
Well im about to get second job in the next few days...on top of my lease being up and moving back home for a few months ill have a pretty nice income....ive actually been thinking about maybe buying a crotch rocket. As for my car...im not going to lie, the exterior is hell...thats what im going to work on this spring...those are the plans for me...
JDMSTi wrote:
work on selling the RS and save up for a JDM Right Hand Drive Swap on my new Impreza L!how much you selling the RS for?? hopefully to have a car and race it if it's worthy to race. -
finish my turbo kit which should throw me into the 12s, and work on my 13bt half-bridge with a gt40r
I'm finally getting my tranny finished up as I post this. Then I'm going to put the motor/trans into my POS and make it run. I just want to drive it for a while, it's been down for almost a year now. Then after I get to drive it, I'll dyno it and tune it. I'm planning on running around 35psi, assuming everything holds together and doesn't blow up prematurely again.
i came across this tonight....seems like it would be a nice project
hopeing to break into the low 14s or high 13s will see if i can get my pos to do it i might bring my stang out if i get it done
