  4. Pre-Season
Pre-Season
44 Posts 20 Posters 2.3k Views
    Purchased:
    Rims
    6 Bolt Motor
    6 Bolt Flywheel
    Rebuilt Transmission
    Boost Gauge
    Oil Pres Gauge
    Water Temp Gauge
    Full Replacement Pillar
    Sparco Lowering Springs
    Balance Shaft Removal Kit
    Hopefully soon:
    Reverse Indiglo Gauges 😉
    FMIC
    Type S or RS BOV
    Big Turbo
    Injectors
    Possible:
    2G Pistons
    Different rice pipe
    New Bearings
    LSD
    Stupid things:
    Fix Downpipe
    Fix interior plastic panel creeks
    Passenger Side Door Hinge Aligned correctly ( i fucked it up making lambo door hinges lol)
    Get my heatcore flushed (or whatever wes told me to do to get my heat working right again)
    • LT1L Offline
      LT1L Offline
      LT1
      i'm serious man
        Your serious?!!?!?
        Your putting an aluminum wing on the 3g?
        Your putting 20's on the 2G?
        R1 -> R6?
        Uhh... do some explaining!
          YellowEvo wrote:
          when you gonna have that new part of the shop goin??
          Soon very soon. It was supposed to be jan 1 but the current resident was unable to move out due to having back surgery. According to them they have started the move so we should have it available i would assume w/in 2 weeks.
          • LT1L Offline
            LT1L Offline
            LT1
            the wing will help sell the 3g, teh 20s will help sell the 2g, and teh only way to rid teh R1 is to downgrade
              you sure the aluminum wing is gonna help sell the 3g? Its so clean how it is now!
              also, for how much you spend on the 20's are you gonna be able to make money just buy buyin them?
                Lt get a clue!!
                kevin
                • My NOvaM Offline
                  My NOvaM Offline
                  My NOva
                  be able to race at the track this summer un like last summer 😞 hopeing to break into the low 14s or high 13s will see if i can get my pos to do it i might bring my stang out if i get it done
                  Hey Tina come get some hamm
                    Well im about to get second job in the next few days...on top of my lease being up and moving back home for a few months ill have a pretty nice income....ive actually been thinking about maybe buying a crotch rocket. As for my car...im not going to lie, the exterior is hell...thats what im going to work on this spring...those are the plans for me...
                    • J Offline
                      J Offline
                      JDMSTi
                      work on selling the RS and save up for a JDM Right Hand Drive Swap on my new Impreza L!
                        JDMSTi wrote:
                        work on selling the RS and save up for a JDM Right Hand Drive Swap on my new Impreza L!how much you selling the RS for?? hopefully to have a car and race it if it's worthy to race.
                        • LT1L Offline
                          LT1L Offline
                          LT1
                          • harwood39H Offline
                            harwood39H Offline
                            harwood39
                            Whats so bad about wings if i may ask. I have one on my civic. I do understand they are rice but still.
                            2730 5th Ave S. Unit C
                            Fargo, ND 58103
                            701-429-3686
                            • theflatlanderT Offline
                              theflatlander
                              finish my turbo kit which should throw me into the 12s, and work on my 13bt half-bridge with a gt40r 😄
                              Fake I.D. says she's legal...game on.
                              88 RX-7 GXL- RB header,pre-mix, SAFCII, SS oil cooler lines,5-speed conv, ACT 6-puck, 9.5lb flywheel, poly bushings, toe-elim,rear camber rod, RB sway bars&endlinks,Stance GR+ Pros, FD3S wheels/REO1Rs...
                                Plans.....hmmmm.......make the motor breath a little better, force some more air through the engine, a little laughing gas to make me feel better after I lose to Dave/Matt/Ethan/GSR/Kevin/etc....
                                  I'm finally getting my tranny finished up as I post this. Then I'm going to put the motor/trans into my POS and make it run. I just want to drive it for a while, it's been down for almost a year now. Then after I get to drive it, I'll dyno it and tune it. I'm planning on running around 35psi, assuming everything holds together and doesn't blow up prematurely again.
                                    what turbo troy?
                                      i came across this tonight....seems like it would be a nice project 🙂
                                      http://www.autotrader.com/fyc/vdp.jsp?car_id=175297663&dealer_id=&car_year=1994&make=MIT&distance=300&max_price=6000&model=ECLIP&advcd_on=n&end_year=2006&min_price=&certified=n&address=58102&search_type=used&advanced=n&start_year=1981&color=&cardist=165
                                      • LT1L Offline
                                        LT1L Offline
                                        LT1
                                        dont u people get it by now.... DSM = POS
                                          5g's for A RICED OUT FIRST GEN....????wtf
