Droooooolllll
2wheeler;246485 wrote:
Awwwww......silly cars.The NLR bikes.
1.2X 60's
7.1X ETs
20X TrapsStock block, stock displacement, hand clutch, DOT tire, no bars, lights, streetable.
SLOW!!!!!
[SIZE=3]Put those lil things away Ethan. Someones gonna loose an eye. [/SIZE]
fdfreak;246459 wrote:
ok, ask travis how much he has into his civic (its nothing extravegant, but respectable). I think he said he was putting down somewhere between 320-340 in his coupe and at the track he was running mid 12's.I dont know very many people around here with V8's, but I am willing to bet it would cost more to build a v8 to see the same track times.
Im not saying thats the case everytime. but probably majority.
weshole;246464 wrote:
What people fail to take into consideration is the very reason I went sport compact was the ability to make reasonable power not only cheap but to keep the car economical in the process. Not that it cant be done in a V8 but its not going to be cheap to make your typical SBC economical and have reasonable power to boot. Meanwhile.... someone comes along and with as quick a car (more agile too) and having half the $$ into it.Disregard platforms I am just asking how I-4's are cheaper to mod than V-8's...
Lets just compare one motor of each one....
the SR20.... factory boost built engine
and
the lq4/lq9..... na built 6.0l LSX truck motor
lets say both stock blocks will handle around 500whp without a problem.... K fair enough
Now lets build a forged aftermarket shortblock for each.... dollar to dollar and potential to potential of eachA set of Eagle rods for a SR is gonna be nearly the same money as for a set of Eagle rods for the LSX..... even though you are getting double the amount of rods...(kind of a rip off)
aftermarket cranks, pistons, ect are gonna be a similar situation..... so you are not going to save much money on building the I-4....
Now look at the potential of each of those forged motors..... what is the built SR gonna push reliably and what is the built LSX gonna push reliably??? not even in the same category
You are going to spend similar amounts of $$ on each for a forced induction setup, it is apples to apples for both there
Ususally the V8 is in a much heavier platform from the get go, and has overcome that,..............but if the v8 is in a lightweight RWD platfrom like an FC or S13...... where does the potential of the car go??
Don't anyone give me the argument on the V8's weighing more or whatnot..... shit the ls1 weighs a similar amount to most I-4's and is 200lbs lighter than a 2jz -
SR > Honda motor lol. its common sense though the bigger engine will make more power and zbrowns right with the weight difference between and LSX motor and some I4s. i think the SR20 comes in at around 600lbs or so. it comes down to personal preference unless your shooting for some very high hp goals. then youll start spending a lot of money on the 4 cylinder.
zbrown;246516 wrote:
As long as it isn't FWD..... I like itQFT
Zach really is hitting the nail right on the head for a lot of us, I just wanted to add one thing, even though the power potential of both of mister Brown's examples are similar. The LSX is going to be a lot more fun to drive on the street as its torque is going to come on much lower and in most situations will nearly match, if not beat, the horsepower #'s. I have yet to see an I4 that makes even close to as much torque as it does horsepower.
fdfreak;246453 wrote:
Most of us "ricers" (I hate that freaking word) build what we can afford. and its alot cheaper to hop up a 4cyl than a V8.You should seriously reconsider that statement.
V8 parts are cheap and readily available....now if you want to start putting 200hp/liter out, that might be a little different, however a 500 whp 350cid engine is much cheaper and more reliable than most 4 cylinders trying to achieve that same goal.
KA-T_240;246534 wrote:
I could put a 500hp v8 in my 240. It would be faster, more reliable, get better gasmileage, and if i would have done it from the start probably cheaper. Then my KA-T setup.why didn't you? what kind of gas mileage are you getting? must not be very good if a 500hp v8 would get better.
tjamz;246533 wrote:
You should seriously reconsider that statement.you must have missed where I said "ok, you win" after Gary's statement. ok, I was wrong. lets get over it. should we get back to the original point of this post or does someone else want to tell me im wrong?
Why is anyone argueing that v8s are cheaper to make go fast than 4 cylinders? thats just retarded. Gary, a few reason sI, and I'm sure other import owners, Choose to mod 4 cylinders rather than v8s include:
-Domestic cars that are affordable are ugly.
-ability to double the horsepower on a motor with no internal modification and keep it reliable.And the most important reason:
-The look on a Yuppie Porsche/Mustang/Camaro/Corvette owners face when you pull away from them in a Rusty Honda Civic Hatchback that sounds like a Sneezing chain saw.
Why is anyone arguing that v8s are cheaper to make go fast than 4 cylinders? Thats just retarded. Gary, a few reasons I, and I'm sure other import owners, choose to mod 4 cylinders rather than v8s include:
-ability to double the horsepower on a motor with no internal modification and keep it reliable.And the most important reason for staying with 4 cylinders...
-The look on a Hick/Yuppie Porsche/Mustang/Camaro/Corvette owners face when you pull away from them in a rusty Honda Civic hatchback that sounds like a sneezing chain saw.
Oh and a honda civic hatch is not.:icon_puke_l: This is just an opinion anyway.Joel;246544 wrote:
ummm I'll just use the best example I know, bone stock HO 302 150ish to the wheels. Add a $1500 blower, cheaper if you get a used one, 350ish to the wheels on a motor with 0 internal mods and over 100k ticks on the odometer. Will run reliably for another 80k before it needs any major work.On topic - a little paint on that engine would equal hot secks
fdfreak;246536 wrote:
why didn't you? what kind of gas mileage are you getting? must not be very good if a 500hp v8 would get better.cruising with the rotary in my car i never did better than about 20-22mpg usually about 16-18mpg..... and when you were beating on the car at all you could watch the gauge fall
with the 4.8 in my car it did a bit better than 25 on the highway..... alot of vettes with a tune do around that 30 mark......
with a little more work on the tune, i could have been at 30 too
its hard to knock on that
granted a modded 4 cylinder could pull around 40, but 30 is still nothing horrible by any means
