  4. My new ride showed up!!
68 Posts 14 Posters 3.0k Views
  • ParkerP
    ParkerP
    zbrown;247165 wrote:
    its an 85c or 75c... I forget
    its not like it is ancient
    no... its like you dont know how to drive the damn thing... you cant just hop in a track machine and expect it to do what a 4wd will do.... i have logged over 7000 hours in our 95E and i have never had a problem pulling fully loaded beet trucks... you're just a fuckin n00b...
    BlueSRT0483;244555 wrote:
    Trafik Jamz;260984 wrote:
    You are right Parker.
    • zbrownZ
      zbrownZ
      are those front castors your "little helpers" then or what??
      • zbrownZ
        zbrownZ
        I know, because it won't period..... unless a quad track
        quad track > wheeled>>>>>>>>>>>>>>cat
        and rough as shit
        • ParkerP
          ParkerP
          they are marker wheels n00b.... they're on the MT765, they give the sprayer something to follow.... they are on the planter too... god you dont know shit..
          • ParkerP
            ParkerP
            and rough as shit
            im not going to dissagree.. i would take a 4wd as a puller over a track machine... but my point is... you dont know how to drive one...
            • MisterCMKM
              MisterCMKM
              I can vouch that the 95E has no problem pulling my fully loaded ass. 😄
              thrash;315544 wrote:
              Ford is back :)
              • ParkerP
                ParkerP
                that...... sounds really really bad...
                • MisterCMKM
                  MisterCMKM
                  I know what you like to do in your tractor
                  Ford is back :)
                  • zbrownZ
                    zbrownZ
                    sounds like my style....
                    • zbrownZ
                      zbrownZ
                      I picked up the front weight set for this hog today......
                      this little monster will drag your 95e wherever i chose now....even turn while doing it if i wish, and all i have to do is turn the steering wheel...... that is my "technique" for turning
                      • MisterCMKM
                        MisterCMKM
                        snap son
                        Ford is back :)
                        • MisterCMKM
                          MisterCMKM
                          Here ya go Zac, you can put this on that cute little tractor of yours.
                          Ford is back :)
                          • ParkerP
                            ParkerP
                            with 140hp? might as well be a honda...
                            • MisterCMKM
                              MisterCMKM
                              VTAK in a tractor?
                              Ford is back :)
                              • zbrownZ
                                zbrownZ
                                I added Vtak and ITB's...... am at about 442 whp with those mods
                                and if i need the bottles I have propane and nitrous oxide to put me well above 750whp....
                                6070>>95e
                                • ParkerP
                                  ParkerP
                                  damn... you got me...
                                  • dubbsyD
                                    dubbsyD
                                    zbrown;247126 wrote:
                                    Gary and Jason which tractor do you feel is nicer/quieter.... the STX 500 or the 9520??
                                    The ONE tractor i would not have any part of is a Cat.....I had no idea how worthless those things are till I got the privilege of using one on the east side
                                    Now if you're talking big 20s... I haven't run around in a newer 4WD JD yet but I've logged plenty of time in a STX375 and I was happy with it. Even a small STX held its own real well on harder ground with the chisel plow.
                                    Now the Cat Challengers... Burm so damn bad. I can't believe guys run those in front of sprayers with as bad as they tear up crop at the end of the field. Its one thing if its wet as fuck and its the only way to get down the field, but if not it just doesn't make sense to me.
                                    on that note, I'm gonna go sit in my Freightliner all day again today. Hopefully the propane showed up today so we can get back to drying corn.
                                    • S
                                      S
                                      squawsnatch
                                      MisterCMK;246999 wrote:
                                      Steiger > NH
                                      .........that looks like it belongs next to the black person hanging it the barn.
                                      • MisterCMKM
                                        MisterCMKM
                                        lulz
                                        Ford is back :)
                                        • GrrG
                                          GrrG
                                          zac is talking about the old 80s model year cat 75c on the farm, that thing is a giant POS. zac you have no idea about these new ones. I was still having problems with the wheels spinning in the track, but i guess they came out and upped the track tension and that too care of it.
