  4. compressor map
compressor map
77 Posts 10 Posters 3.6k Views
    escorts >> civics........
      i'm i the only one confused by captain doushe? :icon_scratch:
      but any way i really want to see this spool a 20g for the street. it will be laggy, but should make good power. if it doesn't blow up, j/k
      • no_slow_clapN Offline
        no_slow_clap
        That car looks oddly familiar, did you go to south?
        a 20g will be more than enough for that. but make sure your engine is going to support it.
        i would recomend arp's...if they make them for you app. and a good tune....GOOD TUNE
        EVOLUTION VIII
          lol...you serious? They make rod bolts/head studs for like nearly any make
            I'm kinds confused here... so it's a 1.8 4cyl with 4 valves? umm how does that work (1 valve per cyliner).. intake and exhaust in the same one, lol?
            • Bp-08B Offline
              Bp-08B Offline
              Bp-08
              yea went to south
              • Bp-08B Offline
                Bp-08B Offline
                Bp-08
                lolz motor is getting a full rebuild, and thats not what i need to worry about. these things are pretty much bullit proof. but the tranny is made outa glass.
                  What kind of tuning/engine management do u plan on using?
                  • Bp-08B Offline
                    Bp-08B Offline
                    Bp-08
                    megasquirt
                    • Bp-08B Offline
                      Bp-08B Offline
                      Bp-08
                      update just bought that turbo, its on its way. oh and anybody here know anyone that is good at welding cast to steel?
                        why would you be welding cast to steel? let me guess your welding a turbo flange to a stock header?
                        • Bp-08B Offline
                          Bp-08B Offline
                          Bp-08
                          kinda.... a wastegate flange to a stock turbo manifold
                            no_slow_clap
                            i thought the 20g is internally gated.
                            EVOLUTION VIII
                            • Bp-08B Offline
                              Bp-08B Offline
                              Bp-08
                              im guessing you can get it either way.
                                no_slow_clap
                                also, stock turbo manifold? im guessing you mean the mani off the first gen probe GT's?
                                EVOLUTION VIII
                                • Bp-08B Offline
                                  Bp-08B Offline
                                  Bp-08
                                  no.. mazda 323 gtx. same motor
                                    no_slow_clap
                                    o, that makes a lot more sense.
                                    EVOLUTION VIII
                                    • Bp-08B Offline
                                      Bp-08B Offline
                                      Bp-08
                                      yea i figured i got the manifold for 100 bucks, and say it cost another 100 to get a wastegate flange welded to it, itll still be cheaper than paying 400 plus for a custom manifold. one day i will get a nice maniflold but right now this will work lol
                                        no_slow_clap
                                        yea, that works. be prepared for it to crack though. cast manifolds like to do that.
                                        EVOLUTION VIII
                                        • Bp-08B Offline
                                          Bp-08B Offline
                                          Bp-08
                                          yea that is a problem but hopefully i will have a better manifold before that happens. im just kinda working on a tight budget right now because i want to get this thing running by summer and i still need to get a lot of things.
