  4. megasquirt
megasquirt
41 Posts 15 Posters 2.1k Views
  • Bp-08B Offline
    Bp-08B Offline
    Bp-08
    anyone here fimilar with tuning megasquirt. thats what i plan on running and it will be my first time attempting to tune lol. should be fun. i might need some help haha
      Nate (91nbtsi) used it on his old Corolla.
      • Bp-08B Offline
        Bp-08B Offline
        Bp-08
        thanks hope he chimes in or ill have to pm him sometime
          1990tsi is going to run it on his corolla... I believe he's gonna have DB in the cities tune it on the dyno...
            • 91nbtsi9 Offline
              91nbtsi9 Offline
              I have tuned megasquirt a fair amount. What would you like to know? It is just like tuning with any other standalone ECU. Get a wideband and you will have a much easier time.
                • GoodnbuzzdG Offline
                  GoodnbuzzdG Offline
                  Goodnbuzzd
                  Yes, get a wideband guage, it will make it much easier to tune.
                    Do you plan on building the MS ECU yourself? Or does the Miata 1.8 lt plug and play work? MAP or Ron will be tuning my car. I would like to have Ron do it, but I just don't know if he'll touch MS or not.
                    • Bp-08B Offline
                      Bp-08B Offline
                      Bp-08
                      yea im getting a innovative wideband w/ gauge, ms2 ecu, plug and play wiring harness, 4 bar map sensor ( you never know lol) for 900 bucks
                      • Bp-08B Offline
                        Bp-08B Offline
                        Bp-08
                        no there is a guy on club protoge that builds megasquirt for escorts, protoges,323's and tracers. the miata one doesnt work due to their distributorless ignition. yea from what ive heard a lot of tuners wont even touch MS. i might try to tune myself. many people have bought from him and i guess he is really good with helping out on tuning.
                          the one built in is good to 21 psi... why would you buy the 4 bar?
                          • Bp-08B Offline
                            Bp-08B Offline
                            Bp-08
                            incase i ever want to go to 22 psi lol no but in the future i will be upgrading, and might as well do it now.
                              you mean in case you ever want to run over 40psi?
                              • Bp-08B Offline
                                Bp-08B Offline
                                Bp-08
                                well ya but i will never run that high psi lol. mainly because the 4 bar has barometric correction and its the same price as the 3 bar. why not lol. but good point i should have explained better. why would i need barometric correction you may ask? well simply because i can lol and again with the same price of 3 bar.
                                  i have an aem ems in my car and everyone i talk to with my platform doesnt use baro corrections. if you are using speed density why do you need baro corrections.. matt, dave, nate, and anyone else i dont konw about, maybe you can help with this question too?
                                  • Bp-08B Offline
                                    Bp-08B Offline
                                    Bp-08
                                    im pretty new to this stuff so ill let some pros chime in. lol i tried to type what i was thinking but i am too tired and after i read it, it pretty much made no sense.
                                    • gsrEKG Offline
                                      gsrEKG Offline
                                      gsrEK
                                        GoodnbuzzdG Offline
                                        Goodnbuzzd
                                        cant use with distributorless ignition???? hmm you can use it with just about anything, with the right parts. building it yourself is part of the fun.
                                          thrash
                                          baro correction is only relevant if you'll be changing altitutdes (or if you drive into a hurricane or something) during the same "boot" of the MS ECU. Otherwise, it reads the base pressure upon bootup and that's what it goes with.
                                          Last time I had looked, multi-sensor baro correction in MS was quite primitive.
                                          I think I'd skip fooling with it for your first build, to be honest. I'd also stick with the normal map sensor.
                                          A distributorless ignition isn't necessarily a problem with MS. On some builds you'd want to read the crank position via the hall sensor on the distributor, but a 60-2 wheel is a better place to read from anyway. For actually getting the spark to the right hole at the right time you've got a few options, espeically if you load the MS2-Extra software into the system.
                                          I've got a built MS2 setup that I never got around to installing that is forsale, btw.
