  4. megasquirt
megasquirt
41 Posts 15 Posters 2.7k Views
  • 91nbtsi9
    91nbtsi9
    I have tuned megasquirt a fair amount. What would you like to know? It is just like tuning with any other standalone ECU. Get a wideband and you will have a much easier time.
    • K
      K
      • GoodnbuzzdG
        GoodnbuzzdG
        Goodnbuzzd
        Yes, get a wideband guage, it will make it much easier to tune.
        • JoelJ
          JoelJ
          Do you plan on building the MS ECU yourself? Or does the Miata 1.8 lt plug and play work? MAP or Ron will be tuning my car. I would like to have Ron do it, but I just don't know if he'll touch MS or not.
          • Bp-08B
            Bp-08B
            Bp-08
            yea im getting a innovative wideband w/ gauge, ms2 ecu, plug and play wiring harness, 4 bar map sensor ( you never know lol) for 900 bucks
            • Bp-08B
              Bp-08B
              Bp-08
              no there is a guy on club protoge that builds megasquirt for escorts, protoges,323's and tracers. the miata one doesnt work due to their distributorless ignition. yea from what ive heard a lot of tuners wont even touch MS. i might try to tune myself. many people have bought from him and i guess he is really good with helping out on tuning.
              • JoelJ
                JoelJ
                the one built in is good to 21 psi... why would you buy the 4 bar?
                • Bp-08B
                  Bp-08B
                  Bp-08
                  incase i ever want to go to 22 psi lol no but in the future i will be upgrading, and might as well do it now.
                  • 24valvenotak2
                    24valvenotak2
                    you mean in case you ever want to run over 40psi?
                    63vette;288530 wrote:
                    • Bp-08B
                      Bp-08B
                      Bp-08
                      well ya but i will never run that high psi lol. mainly because the 4 bar has barometric correction and its the same price as the 3 bar. why not lol. but good point i should have explained better. why would i need barometric correction you may ask? well simply because i can lol and again with the same price of 3 bar.
                      • 24valvenotak2
                        24valvenotak2
                        i have an aem ems in my car and everyone i talk to with my platform doesnt use baro corrections. if you are using speed density why do you need baro corrections.. matt, dave, nate, and anyone else i dont konw about, maybe you can help with this question too?
                        • Bp-08B
                          Bp-08B
                          Bp-08
                          im pretty new to this stuff so ill let some pros chime in. lol i tried to type what i was thinking but i am too tired and after i read it, it pretty much made no sense.
                          • gsrEKG
                            gsrEKG
                            gsrEK
                            • GoodnbuzzdG
                              GoodnbuzzdG
                              Goodnbuzzd
                              cant use with distributorless ignition???? hmm you can use it with just about anything, with the right parts. building it yourself is part of the fun.
                              • T
                                T
                                thrash
                                baro correction is only relevant if you'll be changing altitutdes (or if you drive into a hurricane or something) during the same "boot" of the MS ECU. Otherwise, it reads the base pressure upon bootup and that's what it goes with.
                                Last time I had looked, multi-sensor baro correction in MS was quite primitive.
                                I think I'd skip fooling with it for your first build, to be honest. I'd also stick with the normal map sensor.
                                A distributorless ignition isn't necessarily a problem with MS. On some builds you'd want to read the crank position via the hall sensor on the distributor, but a 60-2 wheel is a better place to read from anyway. For actually getting the spark to the right hole at the right time you've got a few options, espeically if you load the MS2-Extra software into the system.
                                I've got a built MS2 setup that I never got around to installing that is forsale, btw.
                                • inspector01I
                                  inspector01I
                                  Im sure ron will do it with a little convincing. I have something to show you and I promise you will never go to MAP.
                                  I really think on your first build you will have enough to deal with to not have to worry about a barometer setup. Unless you need a new map, i would start with the stock map sensor, and then upgrade when you need to. Saves some money and the start in case you have problems, and possibly saves some headaches if you have any problems with it.
                                  • D
                                    D
                                    dynotune
                                    i haven't looked @ms software in years, but 4 bar resolution sucks, plain and simple. street cars with 4 and 5 bars do not have proper idle properties and drivabilty ESPECIALLY if you have camshafts or low vacuum @ idle scenarios. Baro correction is generally not needed on street cars, but it is ALWAYS in OEM calibrations and there is reasons for that. Most of the stand alone systems are pretty gross in how they work compared to an OEM quality PMC/ software. Yes, anything you can get will work, but there is many disadvantages to stand-alones in alot of cases.
                                    DynoTune Speed & Performance
                                    Mobile chassis dyno service
                                    www.dynotuneusa.com
                                    (605) 753-1101
                                    • bubbaB
                                      bubbaB
                                      • JoelJ
                                        JoelJ
                                        Megasquizz is for cars that don't have engine management. its universal...
                                        • bubbaB
                                          bubbaB
                                          Arent there ones that have been put together to they a plug and play for certain cars...
