  2. Introductions
  3. Introductions
  4. Sort of new
Sort of new
28 Posts 22 Posters 1.8k Views
  • TeamCrankWalkT Offline
    TeamCrankWalk
    Been on the forum for quite sometime, but haven't posted in probably well over a year. The name is Alex, I'm originally from Minot, but looking to attend NDSU in the near future. I have a few rides, but my 92 Plymouth Laser RS AWD is my top choice. Started the project about 5 years ago and this is where it sits today. It's got a few bells and whistles🆒
    • Evo-lutionE Offline
      Evo-lutionE Offline
      Evo-lution
      Hey alex! I seem to see you somewhere....else haha
      <>2003 WW Evo8<>
      <>2005 Honda Crf50<>
      <>1990 VW Corrado G60<>
        TeamCrankWalk
        NA is just a hop and skip away haha.
          Welcome
          • gsrEKG Offline
            gsrEKG Offline
            gsrEK
            welcome and i like your username
            2009 Yamaha Zuma 125, gas HOG
            2008 Honda Fit daily
            A s2k
            1991 Honda civic DX Mint SOLD
            1988 Mitsubishi Mighty max
            > BlackEJ8;233529 wrote:
            • 99civic9 Offline
              99civic9 Offline
              99civic
              welcome.. looks clean
              any more pics?
              2000 civic SiR - jdm sickness
              • 3_Series3 Offline
                3_Series3 Offline
                3_Series
                Welcome.
                Mod list?
                2002 Subaru Legacy
                1993 BMW 325i (sold)
                  TeamCrankWalk
                  Rebuilt 6bolt block with 4bolt rear end.
                  Performance Mods.
                  HKS 272 exhaust 264 intake camshafts
                  Ross Racing 8:5-1 compression forged aluminum pistons
                  Eagle H beam rods with ARP hardware
                  Polished and balanced crankshaft
                  Block bored .030 over
                  SS valves
                  Magnacore 10mm wires
                  NGK BR7ES spark plugs
                  Aeromotive FPR with SS lines
                  Road race engineering catch can
                  Greddy catch can
                  Walbro 255hp fuel pump
                  Walbro 255hp inline fuel pump
                  Rewired fuel pumps
                  SS fuel lines
                  DSM Link
                  Maf Translator
                  Eprom ECU
                  FIC 650cc injectors
                  Aem Uego Wideband
                  Turbonetics dual ball bearing 62-1
                  2.5 Jet-hot2000 coated o2
                  SFP Tubular Manifold coated with jet-hot2000
                  Tial 38mm External Wastegate w/ Dump Tube
                  Mitsu multilayer metal exhaust gasket
                  Push lock style return line with AN fittings
                  SS oil feed line
                  Mitsu 4layer head gasket
                  ARP head studs
                  Mitsu timing belt kit
                  Mitsu oem gasket kit
                  Act 2600 with pressure plate, street disk, mitsu throw out bearing and street light flywheel
                  SS clutch line
                  CNC extended slave cylinder rod
                  Greddy type s bov
                  HKS type 1 turbo timer
                  Symbroski shift kit
                  Reinforced shifter bushings
                  2g shift knob
                  EGR block of plate
                  ABS removed
                  Cruise control removed
                  All emissions eliminated
                  1g non turbo throttle cable
                  Full AC system removed
                  Autometer 2 and 3/8 phantom boost gauge
                  Autometer 52mm phantom oil psi gauge with relocated sender on ss line
                  Greddy EGT gauge
                  Prothane motor mounts
                  Data logger from dsmloggers.com
                  Auto meter 2 and 5/8ths carbon fiber gauge cup
                  Dash insert to hold SAFC2 and cd player
                  Kyb agx struts and shocks
                  Ground control coil overs with Eibach springs
                  3inch intake pipe
                  K&N filter
                  3inch GM maf
                  CX Racing FMIC w/ short route piping
                  1g non turbo throttle body
                  Magnus Motorsports heat barrier intake manifold gasket
                  Dynamic motorsport engineering rear camber kit
                  Energy suspension rear shock bushings
                  Clear timing cover
                  3inch downpipe with 3inch mandrel bent turbo back piping.
                  DNA inline race muffler
                  S&W roll cage
                  RCI one layer fire jacket
                  Driveshaft loop
                  Jeggs sealed battery box
                  There's probably more, but I haven't updated it in a while.
                  Here's a few pictures of what it looks like currently, but some stuff has been removed/replaced since these pictures were taken.
                    Hi 🆒
                    • untitledfolderU Offline
                      untitledfolder
                      What kind of numbers does the Laser put down?
                      > ichibankilla;213613 wrote:
                      2000 Honda Civic CX LS/Vtec
                      http://www.clubredline.net
                      • gsrEKG Offline
                        gsrEKG Offline
                        gsrEK
                        a nice dsm wow. i mean gay dsm haha
                        A s2k
                          welcome dsm'er. ohm is gonna hump your leg
                            TeamCrankWalk
                            Gonna start yelling rape if this keeps up haha. I don't know what numbers its making. Bought the turbo set up from a friend that dynoed some decent numbers untuned and then obviously better tuned so I'm satisfied with the way it sits.
                            • civic91C Offline
                              civic91C Offline
                              civic91
                              welcome
                              04 Toyota Celica Gts
                              • SlowicaS Offline
                                SlowicaS Offline
                                Slowica
                                welcome, quite the mod list there.
                                • kylushK Offline
                                  kylushK Offline
                                  kylush
                                  Welcome.. dsms ftw
                                  1998 Z28 Camaro
                                    welcome
                                    • ruthless351R Offline
                                      ruthless351
                                      Welcome!
                                      • fdfreakF Offline
                                        fdfreakF Offline
                                        fdfreak
                                        Holy mod list! Welcome or welcome back
                                        12.645@118mph 12.6psi
                                        • capitljC Offline
                                          capitljC Offline
                                          capitlj
                                          Pretty clean DSM you got there, but I hate it because its red.
                                          Welcome.
                                          > Mitch Hedberg wrote:
                                          2004 Impala LS 3.8
