  4. Anyone know anything about hooking up a furnace?
22 Posts 9 Posters 883 Views
  • wa2fastcamaroW Offline
    wa2fastcamaro
    I got a electric furnace to heat my garage. After staring at it for a half hour I figured out how to hook it up but got a few questions still. First what size wiring should I run to it? I used copper 8/3 to test it and not sure if that's correct, as it looks like it was previously hooked up with aluminum 6/3 in the house it was in. And what size breaker should I use? It pops my 30 amp double pull after about 2 mins, bout the time the coils start really heating up. Should I be running a 40 or 50 amp double pull breaker?
    Any help would be awesome. Trying my make my garage a little more comfortable to work in.
    Mike
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
        What is the rating on the unit for watts or amps? It should say what the max size breaker is.
        • D S ohMD Offline
          D S ohMD Offline
          D S ohM
          Im in the shop now...its cold! Im actually running one of the kerosene heaters for once. Someone give answers now!
          I wanna go fast!
            Hire an electrician.
            If you do the wiring you have to have it inspected anyways otherwise its illegal...so just hire someone.
            • slow90gsxS Offline
              slow90gsxS Offline
              slow90gsx
              Grace electric is good.
              • XJHEADX Offline
                XJHEADX Offline
                DelSlow;252961 wrote:
                If you do the wiring yourself, it's illegal...so just hire someone.
                Says who???
                What is the wattage or current rating on the heater???
                30 amp 10 cu
                40 amp 8 cu
                50 6 cu
                  Yeah your right there is probly no wiring regulations and codes what so ever. Infact, rewire your house while your at it.
                    He certainly could re-wire the house doing the work himself. There are standards and codes (NEC) that apply but a homeowner can do his own electrical work.
                      Trafik Jamz
                      I believe to do it properly though, he would need to have it inspected before he connected power...but yeah, I fully plan to wire my entire basement by myself.
                      701.541.3484
                        exactly, just save the time and have someone do it right the first time and meet code.
                          Trafik Jamz
                          uhhh....it only takes a few mins to inspect it, no big deal there...save money and do it yourself.
                          701.541.3484
                          • XJHEADX Offline
                            XJHEADX Offline
                            Where did I say no codes????? My wife and I wired my whole house when we built new in Fargo. The only thing we didn't do is the service entrance cable from meter to panel. I did all the plumbing myself too. Am I licensed in ND for either?? No.
                              its not illegal if its your own house, but it is illegal if you dont pull a permit and have it inspected.
                              • 91nbtsi9 Offline
                                91nbtsi9 Offline
                                It's only illegal if you get caught 🙂
                                  it would be retarded to not have certified wiring. If there was ever a fire or something to that nature your insurance would to you to go fuck yourself.
                                    no they wouldnt, thats why you have it inspected by the city... the same guy that inspects certified electricians.
                                      um yes they would.
                                        And why is that?
                                          DelSlow;253001 wrote:
                                          um yes they would.
                                          i build and wire house. house is inspected/passed. ten years later house burns down. insurance says it was cause i wired it even though it was fine for ten years and passed an inspection. your right, that does make sense. :icon_scratch:
                                          what if you buy a house that was wired by someone other then a certified electrician? are you screwed because you didnt have it rewired? will no insurance company pick you up? oh noes. im glad your not charge of the world.
