  4. amp has power but no sound coming out of sub
33 Posts 9 Posters 2.7k Views
  • i_like_eggsI
    i_like_eggsI
    i_like_eggs
    • theobliviousT
      theobliviousT
      theoblivious
      thanks for all the help, ill give this a shot when i can find another speaker. As for the amp, i believe i bought it from you 2 summers ago :(.
      BOOST....to be continued
      • T
        T
        Trafik Jamz
        Was it that long ago? Dang, thought it was last year sometime.
        LMK if I can be of any further help
        701.541.3484
        701.541.3484
        • theobliviousT
          theobliviousT
          theoblivious
          actually it was last summer. i keep getting my summers confused.
          • BlueSRT0483B
            BlueSRT0483B
            BlueSRT0483
            Trafik Jamz;253601 wrote:
            No
            Turns on w/ ignition...receives signal through speaker level inputs or line output converter
            No....except maybe the fader being set wrong
            Not applicable
            Isn't that what 3 or 4 of us already suggested in some way shape or form? (though it is still good advice)
            --Not familiar with his deck, or didn't know of many with preouts.
            --Figured he was using a line out converter, and I'm not a big fan of them. Better off with a deck w/ preouts.
            --I should of expanded on what I was trying to get at with the wires. What I meant was for him to check not only the wires, but look over the terminals too. You have the terminals on the box, that may have a lose wire, or a lose terminal on the sub itself.
            2004 Dodge SRT-4
            ...Formerly "A853"...
            • theobliviousT
              theobliviousT
              theoblivious
              so i rewired everything on the audio side. (took out the wires from inside the sub, took out the wires connecting to the amp and the sub). I got the sub to turn on and play. however, when i turn up the volume up more than halfway, the sub cuts out and the amp goes into protection mode (red light turns on the amp).
              • theobliviousT
                theobliviousT
                theoblivious
                bump
                • wesholeW
                  wesholeW
                  Blown sub. 99% sure. Youll need to either measure the impedance of the sub or try another one to be sure.
                  • T
                    T
                    Trafik Jamz
                    blown sub or shorted wire (wires touching).
                    701.541.3484
                    • theobliviousT
                      theobliviousT
                      theoblivious
                      fixed the problem...my rcas were kind of bent out of shape, so i got a newer one. Seems to fix the problem nicely. Also, is a capacitor necessary when running an aftermarket amp? Will the sound quality be significantly improved?
                      Thanks again for all your help.
                      • wesholeW
                        wesholeW
                        Unless its a big capacitor, It does no good. A 2nd battery is a better option. But neither one will help in actual sound quality. It's more for making sure the amp(s) never run too low on power.
                        • BlueSRT0483B
                          BlueSRT0483B
                          BlueSRT0483
                          Your amp was pretty small right? Watt-age wise? I think you should be fine w/o one.
                          2004 Dodge SRT-4
                          • T
                            T
                            Trafik Jamz
                            Glad this was resolved.
                            As for the cap.....waste of money in every system on the planet....1000000% snake oil.
                            (and yes, i'm being serious when I say that)
                            701.541.3484
                            • wesholeW
                              wesholeW
                              What I cant figure out is if the rca's were bad connection wise, how did that put the amp into protect mode? Not typically something that you would see as a result of bad rca's.
                              • MisterCMKM
                                MisterCMKM
                                Chuck is a liar. I will sell you a 100 farad capacitor for the smoking deal of $100. 😄 jk, Chuck actually is right.
                                thrash;315544 wrote:
                                Ford is back :)
