amp has power but no sound coming out of sub
thanks for all the help, ill give this a shot when i can find another speaker. As for the amp, i believe i bought it from you 2 summers ago :(.
Was it that long ago? Dang, thought it was last year sometime.
LMK if I can be of any further help
701.541.3484
actually it was last summer. i keep getting my summers confused.
Trafik Jamz;253601 wrote:
NoTurns on w/ ignition...receives signal through speaker level inputs or line output converter
No....except maybe the fader being set wrong
Not applicable
Isn't that what 3 or 4 of us already suggested in some way shape or form? (though it is still good advice)
--Not familiar with his deck, or didn't know of many with preouts.
--Figured he was using a line out converter, and I'm not a big fan of them. Better off with a deck w/ preouts.
--I should of expanded on what I was trying to get at with the wires. What I meant was for him to check not only the wires, but look over the terminals too. You have the terminals on the box, that may have a lose wire, or a lose terminal on the sub itself. -
so i rewired everything on the audio side. (took out the wires from inside the sub, took out the wires connecting to the amp and the sub). I got the sub to turn on and play. however, when i turn up the volume up more than halfway, the sub cuts out and the amp goes into protection mode (red light turns on the amp).
bump
blown sub or shorted wire (wires touching).
fixed the problem...my rcas were kind of bent out of shape, so i got a newer one. Seems to fix the problem nicely. Also, is a capacitor necessary when running an aftermarket amp? Will the sound quality be significantly improved?
Thanks again for all your help.
theoblivious;253895 wrote:
fixed the problem...my rcas were kind of bent out of shape, so i got a newer one. Seems to fix the problem nicely. Also, is a capacitor necessary when running an aftermarket amp? Will the sound quality be significantly improved?Thanks again for all your help.
Your amp was pretty small right? Watt-age wise? I think you should be fine w/o one.
Glad this was resolved.
As for the cap.....waste of money in every system on the planet....1000000% snake oil.
(and yes, i'm being serious when I say that)
jk, Chuck actually is right.
