  4. amp has power but no sound coming out of sub
33 Posts 9 Posters 2.7k Views
  • MisterCMKM
    MisterCMKM
    XJHEAD;253585 wrote:
    No it is working correctly
    Sub or the wires feeding it
    You don't know if you have a audio signal reaching the amp yet. Try the new speaker with wire first.
    Chuck is there a easy way to see if a signal is getting to the amp without putting a new amp in?
    Take a known good source and hook it up to the amplifier.
    thrash;315544 wrote:
    Ford is back :)
    • BlueSRT0483B
      BlueSRT0483B
      BlueSRT0483
      Does your factory HU have RCA preouts? How is the amp knowing how to play the music? Is there a function that turns off your preouts, or whatever is used to to turn off the amp? I know on my deck, I can turn my subwoofer off, but I don't believe it turns off the amp itself.. Just stops sending the singal to power the subwoofers.
      Have you checked the wires on the inside of the speaker box, did any of them come loose?
      2004 Dodge SRT-4
      ...Formerly "A853"...
      • T
        T
        Trafik Jamz
        No
        Turns on w/ ignition...receives signal through speaker level inputs or line output converter
        No....except maybe the fader being set wrong
        Not applicable
        Isn't that what 3 or 4 of us already suggested in some way shape or form? (though it is still good advice)
        701.541.3484
        • i_like_eggsI
          i_like_eggsI
          i_like_eggs
          • theobliviousT
            theobliviousT
            theoblivious
            thanks for all the help, ill give this a shot when i can find another speaker. As for the amp, i believe i bought it from you 2 summers ago :(.
            BOOST....to be continued
            • T
              T
              Trafik Jamz
              Was it that long ago? Dang, thought it was last year sometime.
              LMK if I can be of any further help
              701.541.3484
              701.541.3484
              • theobliviousT
                theobliviousT
                theoblivious
                actually it was last summer. i keep getting my summers confused.
                • BlueSRT0483B
                  BlueSRT0483B
                  BlueSRT0483
                  Trafik Jamz;253601 wrote:
                  No
                  Not applicable
                  --Not familiar with his deck, or didn't know of many with preouts.
                  --Figured he was using a line out converter, and I'm not a big fan of them. Better off with a deck w/ preouts.
                  --I should of expanded on what I was trying to get at with the wires. What I meant was for him to check not only the wires, but look over the terminals too. You have the terminals on the box, that may have a lose wire, or a lose terminal on the sub itself.
                  2004 Dodge SRT-4
                  • theobliviousT
                    theobliviousT
                    theoblivious
                    so i rewired everything on the audio side. (took out the wires from inside the sub, took out the wires connecting to the amp and the sub). I got the sub to turn on and play. however, when i turn up the volume up more than halfway, the sub cuts out and the amp goes into protection mode (red light turns on the amp).
                    • theobliviousT
                      theobliviousT
                      theoblivious
                      bump
                      • wesholeW
                        wesholeW
                        Blown sub. 99% sure. Youll need to either measure the impedance of the sub or try another one to be sure.
                        • T
                          T
                          Trafik Jamz
                          blown sub or shorted wire (wires touching).
                          701.541.3484
                          • theobliviousT
                            theobliviousT
                            theoblivious
                            fixed the problem...my rcas were kind of bent out of shape, so i got a newer one. Seems to fix the problem nicely. Also, is a capacitor necessary when running an aftermarket amp? Will the sound quality be significantly improved?
                            Thanks again for all your help.
                            • wesholeW
                              wesholeW
                              Unless its a big capacitor, It does no good. A 2nd battery is a better option. But neither one will help in actual sound quality. It's more for making sure the amp(s) never run too low on power.
                              • BlueSRT0483B
                                BlueSRT0483B
                                BlueSRT0483
                                Your amp was pretty small right? Watt-age wise? I think you should be fine w/o one.
                                2004 Dodge SRT-4
                                • T
                                  T
                                  Trafik Jamz
                                  Glad this was resolved.
                                  As for the cap.....waste of money in every system on the planet....1000000% snake oil.
                                  (and yes, i'm being serious when I say that)
                                  701.541.3484
                                  • wesholeW
                                    wesholeW
                                    What I cant figure out is if the rca's were bad connection wise, how did that put the amp into protect mode? Not typically something that you would see as a result of bad rca's.
                                    • MisterCMKM
                                      MisterCMKM
                                      Chuck is a liar. I will sell you a 100 farad capacitor for the smoking deal of $100. 😄 jk, Chuck actually is right.
                                      Ford is back :)
