  4. amp has power but no sound coming out of sub
33 Posts 9 Posters 2.7k Views
  • XJHEADX
    XJHEADX
    theoblivious;253566 wrote:
    When i press the power button on my stock head unit.
    Try by-passing that by using the amps power feed into the remote on.
    • DelSlowD
      DelSlowD
      Is it plugged in?
      • theobliviousT
        theobliviousT
        theoblivious
        im sorry im a real newb...are you saying disconnect the remote wire?
        BOOST....to be continued
        • T
          T
          Trafik Jamz
          Aside from what Wes/Bill have suggested:
          have you messed with the fader on the deck? If so, make sure that there is signal going to whichever set of speaker outputs is providing signal to the deck.
          Double check to make sure that somehow the speaker wire hasn't come loose on the sub as that would cause the no output possibility as well.
          701.541.3484
          • wesholeW
            wesholeW
            weshole;253551 wrote:
            If it does, then it has to either be your subwoofer itself or a wire going to it. Either in the enclosure itself or to the enclosure.
            Ya, what we said.
            Like I said in my first post , process of elimination. all of which will take 10 minutes to test all.... MAX. Do it all in that order.
            • XJHEADX
              XJHEADX
              Just re-read your orig. post. You state the amp is getting power. Is there a light on it that turns on when you turn on the H/U? If the light turns on when you turn on H/U then it is not the remote wire. The H/U sends 12 volts via the remote wire to tell the amp to turn on. If power is not being sent on that wire the amp won't turn on. That is why I said just jumper a wire from amp feed to the remote connection to see if it would work. If that is the case then the remote feed wire is the problem. Have you tried the other suggestions?
              • theobliviousT
                theobliviousT
                theoblivious
                yes when i turn on the my HU, there is a blue light that turns on from the amp. Do i still need to jump the two wires?
                I will get another speaker tomorrow from a friend and will test out if the sub is the problem.
                If im understanding everything correctly:
                1. If another speaker works, then its an issue with the sub
                2. if it doesnt work, then its an issue with the amp. Is there any way to determine what is wrong with the amp exactly? Sorry if i am being redundant.
                Thanks for all your help
                • T
                  T
                  Trafik Jamz
                  I believe you bought that amp from me, correct? If so, I can try and get it fixed (under warranty if it hasn't been over a year or so)
                  701.541.3484
                  • XJHEADX
                    XJHEADX
                    No it is working correctly
                    Sub or the wires feeding it
                    You don't know if you have a audio signal reaching the amp yet. Try the new speaker with wire first.
                    Chuck is there a easy way to see if a signal is getting to the amp without putting a new amp in?
                    • MisterCMKM
                      MisterCMKM
                      Take a known good source and hook it up to the amplifier.
                      thrash;315544 wrote:
                      Ford is back :)
                      • BlueSRT0483B
                        BlueSRT0483B
                        BlueSRT0483
                        Does your factory HU have RCA preouts? How is the amp knowing how to play the music? Is there a function that turns off your preouts, or whatever is used to to turn off the amp? I know on my deck, I can turn my subwoofer off, but I don't believe it turns off the amp itself.. Just stops sending the singal to power the subwoofers.
                        Have you checked the wires on the inside of the speaker box, did any of them come loose?
                        2004 Dodge SRT-4
                        ...Formerly "A853"...
                        • T
                          T
                          Trafik Jamz
                          No
                          Turns on w/ ignition...receives signal through speaker level inputs or line output converter
                          No....except maybe the fader being set wrong
                          Not applicable
                          Isn't that what 3 or 4 of us already suggested in some way shape or form? (though it is still good advice)
                          701.541.3484
                          • i_like_eggsI
                            i_like_eggsI
                            i_like_eggs
                            • theobliviousT
                              theobliviousT
                              theoblivious
                              thanks for all the help, ill give this a shot when i can find another speaker. As for the amp, i believe i bought it from you 2 summers ago :(.
                              • T
                                T
                                Trafik Jamz
                                Was it that long ago? Dang, thought it was last year sometime.
                                LMK if I can be of any further help
                                701.541.3484
                                701.541.3484
                                • theobliviousT
                                  theobliviousT
                                  theoblivious
                                  actually it was last summer. i keep getting my summers confused.
                                  • BlueSRT0483B
                                    BlueSRT0483B
                                    BlueSRT0483
                                    Trafik Jamz;253601 wrote:
                                    No
                                    Not applicable
                                    --Not familiar with his deck, or didn't know of many with preouts.
                                    --Figured he was using a line out converter, and I'm not a big fan of them. Better off with a deck w/ preouts.
                                    --I should of expanded on what I was trying to get at with the wires. What I meant was for him to check not only the wires, but look over the terminals too. You have the terminals on the box, that may have a lose wire, or a lose terminal on the sub itself.
                                    2004 Dodge SRT-4
                                    • theobliviousT
                                      theobliviousT
                                      theoblivious
                                      so i rewired everything on the audio side. (took out the wires from inside the sub, took out the wires connecting to the amp and the sub). I got the sub to turn on and play. however, when i turn up the volume up more than halfway, the sub cuts out and the amp goes into protection mode (red light turns on the amp).
                                      • theobliviousT
                                        theobliviousT
                                        theoblivious
                                        bump
                                        • wesholeW
                                          wesholeW
                                          Blown sub. 99% sure. Youll need to either measure the impedance of the sub or try another one to be sure.
